* .cvsignore, ChangeLog, asm.h, configure.ac, cpu.c, cpu_asm.c,
rtems/score/.cvsignore, rtems/score/cpu.h, rtems/score/cpu_asm.h,
rtems/score/or16.h, rtems/score/types.h: Removed as the or16 port
was just a stub and only the OR32 port is getting worked on.
* Shell added for or16 port based on no_cpu port with names replaced.
part of the Thread Handler. This required the name of the optional
CPU dependent IDLE thread implementation to change.
like signal dispatching.
