* configure.ac: Move RTEMS_TOP one subdir down.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* configure.ac: Requires automake >= 1.8.1.
* Makefile.am: Include compile.am, again.
* Makefile.am: Convert to using automake compilation rules.
* Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES.
* Makefile.am:Restore further parts having been lost.
* Makefile.am: Restore file having been broken in last commit.
* Makefile.am: Remove TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* Makefile.am: Don't use gmake rules for preinstallation.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all
references.
* cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/cpu_asm.h,
rtems/score/no_cpu.h, rtems/score/types.h: URL for license changed.
* cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
* configure.ac: Require autoconf-2.57 + automake-1.7.2.
* Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS.
* configure.ac: Fix package name.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems.c: Remove.
* configure.ac: Add RTEMS_PROG_CCAS
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
* rtems/score/no_cputypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/Makefile.am: Removed.
* Makefile.am: Add multilib support.
This was tracked as PR91.
* configure.in: Remove.
* rtems/score/no_cpu.h: Modified so there are fewer and
more consistent variations on "no cpu" so it is easier
to sed the source as the starting point for a new port.
_Interrupt_Manager_initialization.
