path: root/cpukit/score/cpu/no_cpu/rtems/score/cpu.h (unfollow)
2018-01-25Remove make preinstallChris Johns1-1501/+0
2017-07-25score: Add optional _CPU_Context_Destroy()Sebastian Huber1-0/+19
Update #3077.
2017-01-26score: Delete _CPU_Context_Fp_start()Sebastian Huber1-26/+0
Since the FP area pointer is passed by reference in _CPU_Context_Initialize_fp() the optional FP area adjustment via _CPU_Context_Fp_start() is superfluous. It is also wrong with respect to memory management, e.g. pointer passed to _Workspace_Free() may be not the one returned by _Workspace_Allocate(). Close #1400.
2017-01-24Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIANSebastian Huber1-40/+0
Use de-facto standard BYTE_ORDER instead. Close #2803.
2016-12-02score: Fix ARM and PowerPC context initializationSebastian Huber1-0/+4
Update #2751.
2016-11-23score: Robust thread dispatchSebastian Huber1-0/+12
On SMP configurations, it is a fatal error to call blocking operating system with interrupts disabled, since this prevents delivery of inter-processor interrupts. This could lead to executing threads which are not allowed to execute resulting in undefined behaviour. The ARM Cortex-M port has a similar problem, since the interrupt state is not a part of the thread context. Update #2811.
2016-11-18score: Add _ISR_Is_enabled()Sebastian Huber1-0/+14
In contrast to _ISR_Get_level() the _ISR_Is_enabled() function evaluates a level parameter and returns a boolean value. Update #2811.
2016-11-18rtems: Conditionally define rtems_interrupt_frameSebastian Huber1-1/+1
Update #2808.
2016-11-18score: Move CPU_PER_CPU_CONTROL_SIZESebastian Huber1-22/+0
Move CPU_PER_CPU_CONTROL_SIZE and the optional CPU_Per_CPU_control to <rtems/score/cpuimpl.h> to hide it from <rtems.h>.
2016-11-18score: Remove obsolete definesSebastian Huber1-23/+0
The thread dispatch inline option is no longer used.
2016-11-10score: Move _CPU_Get_current_per_CPU_control()Sebastian Huber1-18/+0
Move _CPU_Get_current_per_CPU_control() from <rtems/score/cpu.h> to <rtems/score/cpuimpl.h>.
2016-09-23score: Fix C/C++ compatibility issueSebastian Huber1-1/+5
Only use CPU_Per_CPU_control if it contains at least one filed. In GNU C empty structures have a size of zero. In C++ structures have a non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero, then this structure is not used anymore.
2016-06-29score: _CPU_SMP_Send_interrupt() documentationSebastian Huber1-4/+0
2016-06-08score: Delete CPU_USE_GENERIC_BITFIELD_DATASebastian Huber1-10/+0
Rename __log2table into _Bitfield_Leading_zeros since it acually returns the count of leading zeros of an 8-bit integer. The value for zero is a bit odd. Provide it unconditionally.
2016-03-04score: Add CPU_MAXIMUM_PROCESSORSSebastian Huber1-0/+6
Maximum number of processors of all systems supported by this CPU port.
2016-02-17no_cpu: Avoid SCORE_EXTERNSebastian Huber1-1/+1
Update #2559.
2016-01-26score: Introduce CPU_CACHE_LINE_BYTESSebastian Huber1-13/+8
Add CPU_CACHE_LINE_BYTES for the maximum cache line size in bytes. The actual processor may use no cache or a smaller cache line size.
2016-01-25score: Delete obsolete CPU_TIMESTAMP_* definesSebastian Huber1-68/+0
Update #2271.
2015-10-26basedefs.h: Add and use RTEMS_NO_RETURNSebastian Huber1-1/+1
2015-09-28SMP: Fix and optimize thread dispatchingSebastian Huber1-14/+25
According to the C11 and C++11 memory models only a read-modify-write operation guarantees that we read the last value written in modification order. Avoid the sequential consistent thread fence and instead use the inter-processor interrupt to set the thread dispatch necessary indicator.
2015-03-05score: Delete unused CPU_UNROLL_ENQUEUE_PRIORITYSebastian Huber1-23/+0
2015-02-17score: Add _CPU_SMP_Prepare_start_multitasking()Sebastian Huber1-0/+12
Update #2268.
2014-09-10Let CPU/BSP Fatal handler have access to sourceDaniel Hellstrom1-1/+1
Without the source the error code does not say that much. Let it be up to the CPU/BSP to determine the error code reported on fatal shutdown. This patch does not change the current behaviour, just adds the option to handle the source of the fatal halt.
2014-07-04score: PR2183: Fix context switch on SMPSebastian Huber1-2/+31
Fix context switch on SMP for ARM, PowerPC and SPARC. Atomically test and set the is executing indicator of the heir context to ensure that at most one processor uses the heir context. Break the busy wait loop also due to heir updates.
2014-05-08score: Fix CPU context usage on SMPSebastian Huber1-3/+23
We must not alter the is executing indicator in _CPU_Context_Initialize() since this would cause an invalid state during a self restart. The is executing indicator must be valid at creation time since otherwise _Thread_Kill_zombies() uses an undefined value for not started threads. This could result in a system life lock.
2014-05-07score: Implement forced thread migrationSebastian Huber1-0/+18
The current implementation of task migration in RTEMS has some implications with respect to the interrupt latency. It is crucial to preserve the system invariant that a task can execute on at most one processor in the system at a time. This is accomplished with a boolean indicator in the task context. The processor architecture specific low-level task context switch code will mark that a task context is no longer executing and waits that the heir context stopped execution before it restores the heir context and resumes execution of the heir task. So there is one point in time in which a processor is without a task. This is essential to avoid cyclic dependencies in case multiple tasks migrate at once. Otherwise some supervising entity is necessary to prevent life-locks. Such a global supervisor would lead to scalability problems so this approach is not used. Currently the thread dispatch is performed with interrupts disabled. So in case the heir task is currently executing on another processor then this prolongs the time of disabled interrupts since one processor has to wait for another processor to make progress. It is difficult to avoid this issue with the interrupt latency since interrupts normally store the context of the interrupted task on its stack. In case a task is marked as not executing we must not use its task stack to store such an interrupt context. We cannot use the heir stack before it stopped execution on another processor. So if we enable interrupts during this transition we have to provide an alternative task independent stack for this time frame. This issue needs further investigation.
2014-04-29score: Statically initialize _ISR_Vector_tableSebastian Huber1-6/+11
2014-04-28score: Add _CPU_Get_current_per_CPU_control()Sebastian Huber1-0/+18
Add optional method _CPU_Get_current_per_CPU_control() to obtain the per-CPU control of the current processor. This is optional. Not every CPU port needs this. It is only an optional optimization variant. In case this macro is undefined, the default implementation using the current processor index will be used.
2014-04-14score: SMP initialization changesSebastian Huber1-8/+36
Add and use _CPU_SMP_Start_processor(). Add and use _CPU_SMP_Finalize_initialization(). This makes most _CPU_SMP_Initialize() functions a bit simpler since we can calculate the minimum value of the count of processors requested by the application configuration and the count of physically or virtually available processors in the high-level code. The CPU port has now the ability to signal a processor start failure. With the support for clustered/partitioned scheduling the presence of particular processors can be configured to be optional or mandatory. There will be a fatal error only in case mandatory processors are not present. The CPU port may use a timeout to monitor the start of a processor.
2014-04-07score: Clarify CPU port alignment requirementsSebastian Huber1-7/+9
2014-04-03score: Rename Priority_bit_map_ControlSebastian Huber1-1/+1
Rename Priority_bit_map_Control in Priority_bit_map_Word.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2014-03-06score: SMP initialization and shutdown changesSebastian Huber1-2/+2
Rename _SMP_Request_other_cores_to_perform_first_context_switch() into _SMP_Request_start_multitasking() since this requests now a multitasking start on all configured and available processors. The name corresponds _Thread_Start_multitasking() and _SMP_Start_multitasking_on_secondary_processor() actions issued in response to this request. Move in source file to right place. Rename PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING into PER_CPU_STATE_READY_TO_START_MULTITASKING. Rename PER_CPU_STATE_BEGIN_MULTITASKING into PER_CPU_STATE_REQUEST_START_MULTITASKING. Rename _SMP_Request_other_cores_to_shutdown() into _SMP_Request_shutdown(). Add a per-CPU state lock to protect all changes. This was necessary to offer a controlled shutdown of the system (atomic read/writes alone are not sufficient for this kind of synchronization). Add documentation for Per_CPU_State. Delete debug output. New tests smptests/smpfatal01 and smptests/smpfatal02.
2014-02-21score: _CPU_SMP_Get_current_processor()Sebastian Huber1-2/+1
Remove RTEMS_COMPILER_PURE_ATTRIBUTE from _SMP_Get_current_processor() and all _CPU_SMP_Get_current_processor(). Make inline ASM statements volatile again. Test smptests/smpmigration01 showed that GCC optimizes too much otherwise.
2014-02-19score: Rename bsp_smp_initialize()Sebastian Huber1-0/+18
Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU port must supply this function.
2014-02-14score: Add CPU counter supportSebastian Huber1-0/+34
Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter.
2014-02-04Add thread-local storage (TLS) supportSebastian Huber1-1/+2
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other architectures need more work.
2013-11-14no_cpu/.../cpu.h: Comment improvementJoel Sherrill1-0/+5
2013-08-09score/cpu: Add CPU_Per_CPU_controlSebastian Huber1-0/+18
Add CPU port specific per-CPU control.
2013-07-17smp: Rename _CPU_Processor_event_receive()Sebastian Huber1-2/+2
Rename to _CPU_SMP_Processor_event_receive().
2013-07-17smp: Rename _CPU_Processor_event_broadcast()Sebastian Huber1-2/+2
Rename to _CPU_SMP_Processor_event_broadcast().
2013-07-17smp: Add and use _CPU_SMP_Send_interrupt()Sebastian Huber1-0/+10
Delete bsp_smp_interrupt_cpu().
2013-07-17smp: Add and use _CPU_SMP_Get_current_processor()Sebastian Huber1-0/+13
Add and use _SMP_Get_current_processor() and rtems_smp_get_current_processor(). Delete bsp_smp_interrupt_cpu(). Change type of current processor index from int to uint32_t to match _SMP_Processor_count type.
2013-05-29smp: Simplify SMP initialization sequenceSebastian Huber1-0/+31
Delete bsp_smp_wait_for(). Other parts of the system work without timeout, e.g. the spinlocks. Using a timeout here does not make the system more robust. Delete bsp_smp_cpu_state and replace it with Per_CPU_State. The Per_CPU_State follows the Score naming conventions. Add _Per_CPU_Change_state() and _Per_CPU_Wait_for_state() functions to change and observe states. Use Per_CPU_State in Per_CPU_Control instead of the anonymous integer. Add _CPU_Processor_event_broadcast() and _CPU_Processor_event_receive() functions provided by the CPU port. Use these functions in _Per_CPU_Change_state() and _Per_CPU_Wait_for_state(). Add prototype for _SMP_Send_message(). Delete RTEMS_BSP_SMP_FIRST_TASK message. The first context switch is now performed in rtems_smp_secondary_cpu_initialize(). Issuing the first context switch in the context of the inter-processor interrupt is not possible on systems with a modern interrupt controller. Such an interrupt controler usually requires a handshake protocol with interrupt acknowledge and end of interrupt signals. A direct context switch in an interrupt handler circumvents the interrupt processing epilogue and may leave the system in an inconsistent state. Release lock in rtems_smp_process_interrupt() even if no message was delivered. This prevents deadlock of the system. Simplify and format _SMP_Send_message(), _SMP_Request_other_cores_to_perform_first_context_switch(), _SMP_Request_other_cores_to_dispatch() and _SMP_Request_other_cores_to_shutdown().
2013-05-10score: Add CPU context validationSebastian Huber1-0/+31
2013-01-10cpukit: Use Consistent Beginning of Doxygen Group NotationJoel Sherrill1-4/+4
This is the result of a sed script which converts all uses of @{ into a consistent form.
2013-01-02score: Doxygen Clean Up Task #5Alex Ivanov1-661/+694
2012-11-27score: Add CPU_Exception_frameSebastian Huber1-0/+22
Add CPU port type CPU_Exception_frame and function _CPU_Exception_frame_print(). The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh, sparc64, and v850 use an empty default implementation of _CPU_Exception_frame_print(). Add rtems_exception_frame and rtems_exception_frame_print(). Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal() with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc, and sparc for unexpected exceptions. Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the BSP_PRINT_EXCEPTION_CONTEXT define used in the default bsp_fatal_extension(). Add test sptests/spfatal26.
2012-11-22score: PR1607: Add and use CPU_SIZEOF_POINTERSebastian Huber1-0/+9
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an integer literal that can be used by the assembler. This value will be used to calculate offsets of structure members. These offsets will be used in assembler code. The size of a pointer is part of the application binary interface (ABI) and thus independent of the actual programming language. The compiler will provide defines to determine the current ABI. We use these defines to select the appropriate CPU_SIZEOF_POINTER value. Static assertions in the new file "cpukit/score/src/percpuasm.c" will ensure that the value of CPU_SIZEOF_POINTER is consistent with the current compiler settings. Also the offset values used by assembler code are verfied.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
