path: root/cpukit/score/cpu/no_cpu/include/rtems/score/no_cpu.h (follow)
* score/cpu/no_cpu: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* Remove make preinstallChris Johns2018-01-251-0/+67
