path: root/cpukit/score/cpu/no_cpu/asm.h (follow)
* Patch rtems-rc-20000711-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-111-1/+1
| | | | | | | | | that decouples exec/ for the sh, m68k and i960 from targopts.h. NOTE: The change to system.h is a hack to enable cpuopts.h for some targets, but keep using targopts.h for others - I know it does *not* work for sparc, mips, i386 and ppc. This will have to be addressed as work continues on multilibing.
* Moved asm.h back up in tree.Joel Sherrill1999-02-191-0/+101
* Moved to proper rtems/scoreJoel Sherrill1999-02-191-101/+0
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-221-1/+1
* added "ifndef" to avoid redefinition warningJoel Sherrill1997-04-071-0/+2
* Added include of targopts.h.Joel Sherrill1997-01-291-0/+1
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-1/+1
* Initial revisionJoel Sherrill1995-05-111-0/+98
