Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary
conditional compilation.
Close #3539.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
The aim of this file is to encapsulate CPU port implementation details.
This helps to hide implementation details from <rtems.h> which
indirectly includes <rtems/score/cpu.h>.
Use a ticket lock implementation based on atomic operations. Delete CPU
port specific SMP lock implementations.
Move the SMP lock implementation to the CPU port. An optimal SMP lock
implementation is highly architecture dependent. For example the memory
models may be fundamentally different.
The new SMP lock API has a flaw. It does not provide the ability to use
a local context for acquire and release pairs. Such a context is
necessary to implement for example the Mellor-Crummey and Scott (MCS)
locks. The SMP lock is currently used in _Thread_Disable_dispatch() and
_Thread_Enable_dispatch() and makes them to a giant lock acquire and
release. Since these functions do not pass state information via a
local context there is currently no use case for such a feature.
for details.
* Makefile.am: Reformat.
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
PR 754/rtems
* rtems/asm.h: New (relocated from .).
* asm.h: Remove (moved to rtems/asm.h).
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* configure.ac: Remove (Merged into$(top_srcdir)/configure.ac).
* Makefile.am: Don't include multilib.am.
Reflect merging configure.ac into $(top_srcdir)/configure.ac.
* Makefile.am: Install asm.h to $(includedir)/rtems.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* Makefile.am: Include compile.am, again.
* Makefile.am: Convert to using automake compilation rules.
* Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES.
* Makefile.am:Restore further parts having been lost.
* Makefile.am: Restore file having been broken in last commit.
* Makefile.am: Remove TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* Makefile.am: Don't use gmake rules for preinstallation.
* configure.ac: Require autoconf-2.57 + automake-1.7.2.
* Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS.
* Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems.c: Remove.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
* rtems/score/no_cputypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/Makefile.am: Removed.
* Makefile.am: Add multilib support.
converted to automake.
bugs.
rm -rf c/src/exec/score/cpu/a29k/wrap
rm -rf c/src/exec/score/cpu/hppa1.1/wrap
rm -rf c/src/exec/score/cpu/i386/wrap
rm -rf c/src/exec/score/cpu/mips64orion/wrap
rm -rf c/src/exec/score/cpu/no_cpu/wrap
patch -p1 < rtems-rc-19991123-rc-2.diff.gz
* I don't see a possiblity to convert the powerpc subdirectory in its
current layout to automake the time being.
* Besides the fact that this subdirectory is not in single-tree building
layout, the actual showstopper is the ifeq $(RTEMS_CPU_MODEL),mpc750)
gmake-conditional in powerpc/Makefile.in, which automake (correctly)
refuses to handle.
* The problem is *not* specific to the powerpc. Other CPUs basically
have similar problems (SH:sh7032 vs sh7045, SPARC: erc32.h in
score/cpu/sparc), but have been lucky to get around real issues (cf.
configuration files below score/cpu/sh/).
* From a configuration focused POV this problem boils down to a
file/subdirectory selection problem:
ppc: 1 or others
sh: 1 out of 2
sparc: 1 out of 1
Automake's means to implement such behavior is using conditionals to be
evaluated at configuration-time. The old configuration scheme however
used make-time conditionals. The SH port was lucky to get around this
issue because it applies a selection from a limited set of possible
selections, the powerpc however applies a selection from an unlimited
set, based on data not being available at configuration time.
* Currently I only see two general solutions:
1) make RTEMS_CPU_MODEL available at configuration time, ie. replace
make-time configuration by configuration-time configuration
2) Perform the selection at build-time, i.e. always install all files,
but use #ifdef #else #endif in source files. This is what the m68k has
exploited at other locations inside of the source-tree.
=> This directory is the last one remaining not using automake below the
whole exec/ hierarchy.
