PR 1914/cpukit
* rtems/score/cpu.h: Document CPU_TIMESTAMP_USE_STRUCT_TIMESPEC,
CPU_TIMESTAMP_USE_INT64, and CPU_TIMESTAMP_USE_INT64_INLINE.
* cpu.c: Remove /*PAGE markers which were interpreted by a long dead
print script.
* Makefile.am: Reformat.
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1599/cpukit
* cpu_asm.c: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1573/cpukit
* cpu_asm.c, rtems/score/cpu.h: Add a per cpu data structure which
contains the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* cpu.c, cpu_asm.c: Add include of config.h
* cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* cpu_asm.c, rtems/score/cpu.h, rtems/score/types.h: Corrections and
updates.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Add CPU_SIMPLE_VECTORED_INTERRUPTS porting
parameter to indicate that the port uses the Simple Vectored
Interrupt model or the Programmable Interrupt Controller Model. The
PIC model is implemented primarily in the BSP and it is responsible
for all memory allocation.
* rtems/score/cpu.h: Remove most doxygen warnings.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* rtems/score/cpu.h: Style.
* rtems/score/cpu.h: Fix Doxygen.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
Use Context_Control_fp* instead of void* for fp_contexts.
Eliminate evil casts.
* rtems/score/types.h: Remove unsigned64, signed64.
* rtems/asm.h, rtems/score/cpu.h, rtems/score/types.h: Part of a large
patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
PR 754/rtems
* rtems/asm.h: New (relocated from .).
* asm.h: Remove (moved to rtems/asm.h).
* asm.h, rtems/score/cpu.h, rtems/score/cpu_asm.h,
rtems/score/no_cpu.h, rtems/score/types.h: New header guards.
* rtems/score/types.h: Remove signed8, signed16, signed32,
unsigned8, unsigned16, unsigned32.
* rtems/score/cpu.h: *_swap_u32( uint32_t ).
* rtems/score/types.h: #include <rtems/stdint.h>.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* rtems/score/types.h: Use __rtems_score_types_h as preprocessor
guard.
* asm.h: Add doxygen preamble.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/cpu_asm.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* rtems/score/cpu.h: i960 obsoleted and all references removed.
* configure.ac: Remove (Merged into$(top_srcdir)/configure.ac).
* Makefile.am: Don't include multilib.am.
Reflect merging configure.ac into $(top_srcdir)/configure.ac.
* Makefile.am: Install asm.h to $(includedir)/rtems.
* cpu.c, rtems/score/cpu.h: Convert to using c99 fixed size types.
* configure.ac: RTEMS_TOP([../../../..]).
* configure.ac: Move RTEMS_TOP one subdir down.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* configure.ac: Requires automake >= 1.8.1.
* Makefile.am: Include compile.am, again.
