* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Add CPU_SIMPLE_VECTORED_INTERRUPTS porting
parameter to indicate that the port uses the Simple Vectored
Interrupt model or the Programmable Interrupt Controller Model. The
PIC model is implemented primarily in the BSP and it is responsible
for all memory allocation.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
Eliminate evil casts.
* rtems/score/types.h: Remove unsigned64, signed64.
* rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/nios2.h,
rtems/score/types.h: New files.
* ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c, preinstall.am,
rtems/asm.h: New files.
