* | score misc: Clean up Doxygen #13 (GCI 2012) | Mathew Kallada | 2012-12-02 | 1 | -0/+6 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8013205 | ||||
* | 2011-09-02 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-02 | 1 | -1/+1 |
| | | | | | * rtems/score/nios2-utility.h, nios2-isr-set-level.c, nios2-isr-get-level.c: Renamed functions. | ||||
* | 2011-09-02 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-02 | 1 | -3/+10 |
| | | | | | | | * rtems/score/nios2-utility.h: Avoid redefines with Altera HAL. Declare _Nios2_ISR_Set_level(). * nios2-context-initialize.c: Use _Nios2_ISR_Set_level(). * nios2-isr-set-level.c: Define _Nios2_ISR_Set_level(). | ||||
* | 2011-09-01 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-01 | 1 | -0/+54 |
* cpu.c, cpu_asm.S: Removed files. * nios2-context-initialize.c, nios2-context-switch.S, nios2-fatal-halt.c, nios2-initialize-vectors.c, nios2-initialize.c, nios2-isr-get-level.c, nios2-isr-install-raw-handler.c, nios2-isr-install-vector.c, nios2-isr-is-in-progress.c, nios2-isr-set-level.c, nios2-thread-dispatch-disabled.c, rtems/score/nios2-utility.h: New files. * Makefile.am, preinstall.am: Reflect changes above. * irq.c: Update due to API changes. * rtems/score/cpu.h: New functions _CPU_Initialize_vectors(), _CPU_ISR_Set_level(), and _CPU_Fatal_halt() (instead of macros). Support for external interrupt controller (EIC). Documentation changes. |
