* | nios2: Make _ISR_Is_in_progress() weak | Sebastian Huber | 2021-02-01 | 1 | -1/+1 |
| | | | | This allows the BSP to override this function. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | score: Simplify <rtems/system.h> | Sebastian Huber | 2015-06-26 | 1 | -1/+1 |
| | | | | | Drop the <rtems/score/percpu.h> include since this file exposes a lot of implementation details. | ||||
* | 2011-09-01 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-01 | 1 | -0/+34 |
* cpu.c, cpu_asm.S: Removed files. * nios2-context-initialize.c, nios2-context-switch.S, nios2-fatal-halt.c, nios2-initialize-vectors.c, nios2-initialize.c, nios2-isr-get-level.c, nios2-isr-install-raw-handler.c, nios2-isr-install-vector.c, nios2-isr-is-in-progress.c, nios2-isr-set-level.c, nios2-thread-dispatch-disabled.c, rtems/score/nios2-utility.h: New files. * Makefile.am, preinstall.am: Reflect changes above. * irq.c: Update due to API changes. * rtems/score/cpu.h: New functions _CPU_Initialize_vectors(), _CPU_ISR_Set_level(), and _CPU_Fatal_halt() (instead of macros). Support for external interrupt controller (EIC). Documentation changes. |
