* | Let CPU/BSP Fatal handler have access to source | Daniel Hellstrom | 2014-09-10 | 1 | -1/+1 |
| | | | | | | | | | Without the source the error code does not say that much. Let it be up to the CPU/BSP to determine the error code reported on fatal shutdown. This patch does not change the current behaviour, just adds the option to handle the source of the fatal halt. | ||||
* | nios2: Use NIOS2_CTLREG_INDEX_STATUS | Jeffrey O. Hill | 2013-03-11 | 1 | -1/+2 |
* | 2011-09-01 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-01 | 1 | -0/+27 |
* cpu.c, cpu_asm.S: Removed files. * nios2-context-initialize.c, nios2-context-switch.S, nios2-fatal-halt.c, nios2-initialize-vectors.c, nios2-initialize.c, nios2-isr-get-level.c, nios2-isr-install-raw-handler.c, nios2-isr-install-vector.c, nios2-isr-is-in-progress.c, nios2-isr-set-level.c, nios2-thread-dispatch-disabled.c, rtems/score/nios2-utility.h: New files. * Makefile.am, preinstall.am: Reflect changes above. * irq.c: Update due to API changes. * rtems/score/cpu.h: New functions _CPU_Initialize_vectors(), _CPU_ISR_Set_level(), and _CPU_Fatal_halt() (instead of macros). Support for external interrupt controller (EIC). Documentation changes. |
