* | score: Rename Priority_bit_map_Control | Sebastian Huber | 2014-04-03 | 1 | -1/+1 |
| | | | | Rename Priority_bit_map_Control in Priority_bit_map_Word. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 8 | -8/+8 |
* | score: Add CPU counter support | Sebastian Huber | 2014-02-14 | 2 | -0/+13 |
| | | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter. | ||||
* | Add thread-local storage (TLS) support | Sebastian Huber | 2014-02-04 | 1 | -1/+1 |
| | | | | | Tested and implemented on ARM, m68k, PowerPC and SPARC. Other architectures need more work. | ||||
* | score: Simplify <rtems/score/cpuatomic.h> | WeiY | 2013-08-28 | 1 | -30/+6 |
| | | | | Add proper license and copyright. | ||||
* | score/cpu: Add CPU_Per_CPU_control | Sebastian Huber | 2013-08-09 | 1 | -0/+6 |
| | | | | Add CPU port specific per-CPU control. | ||||
* | update-all-architectures-to-new-atomic-implementation | WeiY | 2013-07-17 | 1 | -6/+4 |
* | score: Add CPU context validation | Sebastian Huber | 2013-05-10 | 1 | -0/+12 |
* | Revert bootstrap whitespace changes. | Chris Johns | 2013-05-10 | 1 | -0/+1 |
* | Using the generic atomic ops to implement UP mode atomic for all ↵ | WeiY | 2013-05-01 | 3 | -0/+44 |
| | | | | architectures. SMP atomic port will be later. | ||||
* | cpukit moxie: Style corrections | Joel Sherrill | 2013-02-28 | 2 | -71/+7 |
* | Add Moxie CPU support | Anthony Green | 2013-02-28 | 9 | -0/+1647 |
Signed-off-by: Anthony Green <green@moxielogic.com> |
