path: root/cpukit/score/cpu/moxie/rtems/score (follow)
* score: Robust thread dispatchSebastian Huber2016-11-231-0/+2
| | | | | | | | | | | | On SMP configurations, it is a fatal error to call blocking operating system with interrupts disabled, since this prevents delivery of inter-processor interrupts. This could lead to executing threads which are not allowed to execute resulting in undefined behaviour. The ARM Cortex-M port has a similar problem, since the interrupt state is not a part of the thread context. Update #2811.
* score: Add _ISR_Is_enabled()Sebastian Huber2016-11-181-0/+5
| | | | | | | In contrast to _ISR_Get_level() the _ISR_Is_enabled() function evaluates a level parameter and returns a boolean value. Update #2811.
* score: Move CPU_PER_CPU_CONTROL_SIZESebastian Huber2016-11-182-2/+4
| | | | | Move CPU_PER_CPU_CONTROL_SIZE and the optional CPU_Per_CPU_control to <rtems/score/cpuimpl.h> to hide it from <rtems.h>.
* score: Remove obsolete definesSebastian Huber2016-11-181-22/+0
| | | | The thread dispatch inline option is no longer used.
* score: Add <rtems/score/cpuimpl.h>Sebastian Huber2016-11-071-0/+30
| | | | | | The aim of this file is to encapsulate CPU port implementation details. This helps to hide implementation details from <rtems.h> which indirectly includes <rtems/score/cpu.h>.
* score: Fix C/C++ compatibility issueSebastian Huber2016-09-231-4/+0
| | | | | | | Only use CPU_Per_CPU_control if it contains at least one filed. In GNU C empty structures have a size of zero. In C++ structures have a non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero, then this structure is not used anymore.
* score: Simplify priority bit map implementationSebastian Huber2016-06-081-1/+0
| | | | | | | | | | The priority bit map can deal with a maximum of 256 priority values ranging from 0 to 255. Consistently use an unsigned int for computation, due to the usual integer promotion rules. Make Priority_bit_map_Word definition architecture-independent and define it to uint16_t. This was already the case for all architectures except PowerPC. Adjust the PowerPC bitmap support accordingly.
* score: Delete CPU_USE_GENERIC_BITFIELD_DATASebastian Huber2016-06-081-2/+0
| | | | | | Rename __log2table into _Bitfield_Leading_zeros since it acually returns the count of leading zeros of an 8-bit integer. The value for zero is a bit odd. Provide it unconditionally.
* score: Delete dead copy and paste codeSebastian Huber2016-06-081-106/+1
* score: Add CPU_MAXIMUM_PROCESSORSSebastian Huber2016-03-041-0/+2
| | | | Maximum number of processors of all systems supported by this CPU port.
* moxie: Delete superfluous _CPU_Null_fp_contextSebastian Huber2016-02-171-30/+1
| | | | Update #2559.
* score: Introduce CPU_CACHE_LINE_BYTESSebastian Huber2016-01-261-23/+3
| | | | | Add CPU_CACHE_LINE_BYTES for the maximum cache line size in bytes. The actual processor may use no cache or a smaller cache line size.
* score: Delete obsolete CPU_TIMESTAMP_* definesSebastian Huber2016-01-251-4/+0
| | | | Update #2271.
* basedefs.h: Add and use RTEMS_NO_RETURNSebastian Huber2015-10-261-1/+1
* cpukit: add and use CPU_Uint32ptr typeGedare Bloom2015-03-161-0/+4
* score: Delete unused CPU_UNROLL_ENQUEUE_PRIORITYSebastian Huber2015-03-051-23/+0
* moxiertems/score/cpu.h: _CPU_Context_switch needed ↵Joel Sherrill2014-10-091-9/+22
| | | | RTEMS_COMPILER_NO_RETURN_ATTRIBUTE plus fix warnings on unimplemented ISR enable/disable
* Let CPU/BSP Fatal handler have access to sourceDaniel Hellstrom2014-09-101-2/+2
| | | | | | | | | Without the source the error code does not say that much. Let it be up to the CPU/BSP to determine the error code reported on fatal shutdown. This patch does not change the current behaviour, just adds the option to handle the source of the fatal halt.
* score: Rename Priority_bit_map_ControlSebastian Huber2014-04-031-1/+1
| | | | Rename Priority_bit_map_Control in Priority_bit_map_Word.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-214-4/+4
* score: Add CPU counter supportSebastian Huber2014-02-141-0/+12
| | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter.
* Add thread-local storage (TLS) supportSebastian Huber2014-02-041-1/+1
| | | | | Tested and implemented on ARM, m68k, PowerPC and SPARC. Other architectures need more work.
* score: Simplify <rtems/score/cpuatomic.h>WeiY2013-08-281-30/+6
| | | | Add proper license and copyright.
* score/cpu: Add CPU_Per_CPU_controlSebastian Huber2013-08-091-0/+6
| | | | Add CPU port specific per-CPU control.
* update-all-architectures-to-new-atomic-implementationWeiY2013-07-171-6/+4
* score: Add CPU context validationSebastian Huber2013-05-101-0/+12
* Using the generic atomic ops to implement UP mode atomic for all ↵WeiY2013-05-011-0/+40
| | | | architectures. SMP atomic port will be later.
* cpukit moxie: Style correctionsJoel Sherrill2013-02-281-54/+2
* Add Moxie CPU supportAnthony Green2013-02-283-0/+1186
Signed-off-by: Anthony Green <green@moxielogic.com>
