path: root/cpukit/score/cpu/moxie/rtems/score/cpuimpl.h (unfollow)
2016-11-18score: Move CPU_PER_CPU_CONTROL_SIZESebastian Huber1-0/+4
Move CPU_PER_CPU_CONTROL_SIZE and the optional CPU_Per_CPU_control to <rtems/score/cpuimpl.h> to hide it from <rtems.h>.
2016-11-07score: Add <rtems/score/cpuimpl.h>Sebastian Huber1-10/+15
The aim of this file is to encapsulate CPU port implementation details. This helps to hide implementation details from <rtems.h> which indirectly includes <rtems/score/cpu.h>.
2016-09-08testsuite: Add libdl/dl05 reloc test.Chris Johns1-0/+11
2016-08-15testsuite: Add libdl/dl04 cache test.Chris Johns1-1/+1
2014-10-31cpukit: Add libdl with the Runtime Loader (RTL) code.Chris Johns1-9/+5
This is a merge of the RTL project.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2012-10-11Use proper 3 line form of license textJoel Sherrill1-2/+3
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2010-06-172010-06-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-0/+19
* ChangeLog, Makefile.am, acinclude.m4, configure.ac, shared/asm/asm.S, shared/clock/ckinit.c, shared/console/conscfg.c, shared/helenos/LICENSE, shared/helenos/README, shared/helenos/boot/genarch/balloc.c, shared/helenos/boot/genarch/ofw.c, shared/helenos/boot/genarch/ofw_tree.c, shared/helenos/boot/generic/string.c, shared/helenos/boot/include/align.h, shared/helenos/boot/include/balloc.h, shared/helenos/boot/include/gentypes.h, shared/helenos/boot/include/main.h, shared/helenos/boot/include/ofw.h, shared/helenos/boot/include/ofw_tree.h, shared/helenos/boot/include/ofwarch.h, shared/helenos/boot/include/register.h, shared/helenos/boot/include/stack.h, shared/helenos/boot/include/types.h, shared/helenos/boot/sparc64/loader/main.c, shared/helenos/boot/sparc64/loader/ofwarch.c, shared/helenos/boot/sparc64/loader/ofwasm.S, shared/helenos/kernel/genarch/include/ofw/ofw_tree.h, shared/helenos/kernel/generic/include/align.h, shared/helenos/kernel/sparc64/include/arch.h, shared/helenos/kernel/sparc64/include/boot.h, shared/helenos/kernel/sparc64/include/regdef.h, shared/helenos/kernel/sparc64/include/stack.h, shared/helenos/kernel/sparc64/include/mm/cache_spec.h, shared/helenos/kernel/sparc64/include/mm/frame.h, shared/helenos/kernel/sparc64/include/mm/mmu.h, shared/helenos/kernel/sparc64/include/mm/page.h, shared/helenos/kernel/sparc64/include/mm/tlb.h, shared/helenos/kernel/sparc64/include/mm/tte.h, shared/helenos/kernel/sparc64/include/mm/sun4u/frame.h, shared/helenos/kernel/sparc64/include/mm/sun4u/mmu.h, shared/helenos/kernel/sparc64/include/mm/sun4u/page.h, shared/helenos/kernel/sparc64/include/mm/sun4u/tlb.h, shared/helenos/kernel/sparc64/include/mm/sun4u/tte.h, shared/helenos/kernel/sparc64/include/sun4u/arch.h, shared/helenos/kernel/sparc64/src/cache.S, shared/helenos/kernel/sparc64/src/sun4u/takemmu.S, shared/include/asm.h, shared/include/traptable.h, shared/start/start.S, shared/start/trap_table.S, shared/startup/bspgetworkarea.c, shared/startup/bspstart.c, shared/startup/linkcmds, shared/startup/setvec.c: New files.
