line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Signed-off-by: Anthony Green <green@moxielogic.com>
* cpu.c, rtems/asm.h, rtems/score/cpu.h:
PR 1573/cpukit
* cpu_asm.S, rtems/asm.h, rtems/score/cpu.h: Add a per cpu data
structure which contains the information required by RTEMS for each
CPU core. This encapsulates information such as thread executing,
heir, idle and dispatch needed.
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
* asm.h: Add doxygen preamble.
* asm.h, cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/h8300.h,
rtems/score/types.h: URL for license changed.
Hitachi H8 family. This port was done by Philip Quaife
<philip@qs.co.nz> of Q Solutions and sponsored by
Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1
to a Hitach H8300H. The port was updated to RTEMS 4.5 style
Makefiles/configure by Joel Sherrill <joel@OARcorp.com>.
While doing this Joel added support for the h8300-rtems to
binutils, gcc, newlib, and gdb.
NOTE: Philip submitted a BSP for a Hitachi evaluation board
which is being merged as a separate entity.
(ostertag@transition.com).
like signal dispatching.
