* | Cosmetics. | Ralf Corsepius | 2004-11-21 | 4 | -4/+0 |
* | 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-21 | 2 | -2/+7 |
| | | | | | * rtems/score/types.h: Use __rtems_score_types_h as preprocessor guard. | ||||
* | 2004-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-21 | 3 | -6/+14 |
| | | | | * asm.h: Add doxygen preamble. | ||||
* | 2004-10-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-02 | 4 | -4/+20 |
| | | | | | | * rtems/score/cpu.h: Add doxygen preamble. * rtems/score/mips.h: Add doxygen preamble. * rtems/score/types.h: Add doxygen preamble. | ||||
* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 2 | -4/+5 |
| | | | | * rtems/score/cpu.h: i960 obsoleted and all references removed. | ||||
* | 2004-07-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-07-25 | 2 | -42/+27 |
| | | | | | * cpu_asm.S: Remove use of C++ style comments and make this compile again. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 7 | -7/+0 |
* | 2004-04-14 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-14 | 2 | -5/+6 |
| | | | | | | PR 605/bsps * cpu.c: Remove further c++ style comments having been missed in previous patch. Remove printf's entirely. | ||||
* | 2004-04-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-04-09 | 2 | -2/+7 |
| | | | | | PR 605/bsps * cpu.c: Do not use C++ style comments. | ||||
* | Cosmetics. | Ralf Corsepius | 2004-04-06 | 1 | -1/+0 |
* | Cleanup | Ralf Corsepius | 2004-04-06 | 1 | -12/+0 |
* | 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-06 | 3 | -31/+8 |
| | | | | | | * configure.ac: Remove (Merged into $(top_srcdir)/configure.ac). * Makefile.am: Don't include multilib.am. Reflect merging configure.ac into $(top_srcdir)/configure.ac. | ||||
* | 2004-04-03 Art Ferrer <arturo.b.ferrer@nasa.gov> | Joel Sherrill | 2004-04-03 | 3 | -0/+26 |
| | | | | | | | PR 598/bsps * cpu_asm.S, rtems/score/cpu.h: Add save of floating point status/control register on context switches. Missing this register was causing intermittent floating point errors. | ||||
* | 2004-04-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-03 | 4 | -15/+24 |
| | | | | | | | | * Makefile.am: Install iregdefs.h and idtcpu.h to $(includedir)/rtems/mips. * cpu_asm.S: Include <rtems/mips/iregdef.h> instead of <iregdef.h>. * rtems/score/mips.h, cpu_asm.S: Include <rtems/mips/idtcpu.h> instead of <idtcpu.h>. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -4/+16 |
| | | | | * Makefile.am: Install asm.h to $(includedir)/rtems. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -1/+5 |
| | | | | * cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 3 | -23/+27 |
| | | | | * cpu.c, rtems/score/cpu.h: Convert to using c99 fixed size types. | ||||
* | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 2 | -1/+5 |
| | | | | * configure.ac: RTEMS_TOP([../../../..]). | ||||
* | Unused. | Ralf Corsepius | 2004-03-08 | 2 | -4/+0 |
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -2/+7 |
| | | | | * configure.ac: Move RTEMS_TOP one subdir down. | ||||
* | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-19 | 2 | -2/+8 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+9 |
| | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. | ||||
* | 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-12 | 2 | -1/+5 |
| | | | | * configure.ac: Requires automake >= 1.8.1. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -1/+5 |
| | | | | * Makefile.am: Include compile.am, again. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -14/+14 |
| | | | | * Makefile.am: Convert to using automake compilation rules. | ||||
* | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-07 | 2 | -1/+4 |
| | | | | * rtems/score/mips.h: Removed junk revision line. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -4/+6 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -14/+20 |
| | | | | * Makefile.am:Restore further parts having been lost. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -2/+60 |
| | | | | * Makefile.am: Restore file having been broken in last commit. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 2 | -67/+6 |
| | | | | * Makefile.am: Remove TMPINSTALL_FILES. | ||||
* | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-30 | 2 | -14/+24 |
| | | | | * Makefile.am: Add $(dirstamp) to preinstallation rules. | ||||
* | 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-23 | 2 | -19/+36 |
| | | | | * Makefile.am: Don't use gmake rules for preinstallation. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 2 | -7/+5 |
| | | | | | * rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all references. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 6 | -5/+10 |
| | | | | | * cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/mips.h, rtems/score/types.h: URL for license changed. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-11 | 3 | -7/+10 |
| | | | | | * configure.ac: Require autoconf-2.57 + automake-1.7.2. * Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS. | ||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-19 | 2 | -1/+5 |
| | | | | * configure.ac: Fix package name. | ||||
* | 2002-11-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-04 | 3 | -2/+6 |
| | | | | * idtcpu.h: Removed warning. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 3 | -2/+6 |
| | | | | * idtcpu.h: Removed warnings. | ||||
* | 2002-10-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-28 | 3 | -2/+7 |
| | | | | | * idtcpu.h: Removed warning by turning extra token at the end of an endif into a comment. | ||||
* | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-25 | 2 | -1/+5 |
| | | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-08-14 Greg Menke <gregory.menke@gsfc.nasa.gov> | Joel Sherrill | 2002-08-14 | 2 | -41/+44 |
| | | | | | * cpu_asm.S: Clarified some comments, removed code that forced SR_IEP on when returning from an interrupt. | ||||
* | 2002-07-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-26 | 2 | -7/+9 |
| | | | | * Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel. | ||||
* | 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-22 | 2 | -2/+6 |
| | | | | * Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-07-16 Greg Menke <gregory.menke@gsfc.nasa.gov> | Joel Sherrill | 2002-07-16 | 2 | -3/+8 |
| | | | | | * cpu_asm.S: Added SR_IEO to context restore to fix isr disabled deadlock caused by interrupt arriving while dispatching. |
