in ROM.
significant things:
and PowerPC
same code base.
converted to automake.
use correct ifdef conditional (__GNUC__ not __GCC__).
bugs.
rm -rf c/src/exec/score/cpu/i960/wrap
rm -rf c/src/exec/score/cpu/m68k/wrap
rm -rf c/src/exec/score/cpu/sh/wrap
rm -rf c/src/exec/score/cpu/sparc/wrap
rm -rf c/src/exec/score/cpu/unix/wrap
patch -p1 < rtems-rc-19991123-rc-1.diff
./bootstrap
Known bugs:
* "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does
not handle recursion to subdirectories correctly (recurses too often).
However, this issue is hardly visible and should be tolerable for the
moment.
Synthesizer Control Register to remove use of single letter names.
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
outside RTEMS. Comment:
I found a couple of places other than RTEMS where I'd like to use
the declarations supplied in m68360.h. To make this easier to do,
I've redone the declarations in m68360.h to use standard C types.
specific register macros and correct code in rtems.s.
important distinctions between CPU models which are not made by gcc.
These distinctions help give us a more optimized memcpy(). This is important
for message queues and KA9Q.
suggestion.
The definition of "BEGIN_DATA" should not be null; should be ".data".
Also, the definition of "BEGIN_BSS" should be ".bss". For this error,
the compiled object has codes that write on the text segment area.
It is fatal when the code runs on ROM.
software floating point emulation code. Code implemented by
Karen Sara Looney <Karen.Looney@colorado.edu> with much
email assistance from Joel.
for an interrupt stack. Hopefully this will encourage someone to
implement software stack switching on the m68k.
68000 class CPUs.
no longer uses efi332.h
added CPU_M68K_EXTB_L model flag
<jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support
for interrupt handling and bfffo support, the two BSPs he submitted
(efi68k and efi332), and SGI Irix 5.3 host support.
like signal dispatching.
