* | Remove (Obsolete).4.8 | Ralf Corsépius | 2012-02-17 | 1 | -2/+0 |
* | 2007-08-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-08-04 | 2 | -0/+47 |
| | | | | * rtems/score/m68k.h: Add stubs for mcf5307, mcf5407, mcfv4e. | ||||
* | 2007-07-31 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-07-31 | 1 | -0/+5 |
| | | | | | * cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h: Replace M68K_COLDFIRE_ARCH with __mcoldfire__. | ||||
* | Replace M68K_COLDFIRE_ARCH with __mcoldfire__. | Ralf Corsepius | 2007-07-31 | 3 | -20/+19 |
* | 2007-05-22 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-22 | 1 | -2/+0 |
| | | | | | | | | | * score/cpu/arm/cpu.c, score/cpu/avr/cpu.c, score/cpu/bfin/cpu.c, score/cpu/c4x/cpu.c, score/cpu/h8300/cpu.c, score/cpu/i386/cpu.c, score/cpu/m68k/cpu.c, score/cpu/mips/cpu.c, score/cpu/nios2/cpu.c, score/cpu/no_cpu/cpu.c, score/cpu/sh/cpu.c, score/cpu/sparc/cpu.c, cpukit/sapi/src/exinit.c: Move copying of CPU Table to shared executive initialization. | ||||
* | Include <rtems/stdint.h> instead of <stdint.h>. | Ralf Corsepius | 2007-05-09 | 1 | -1/+1 |
* | 2007-05-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-05-09 | 2 | -1/+4 |
| | | | | * rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES. | ||||
* | 2007-04-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-17 | 1 | -0/+5 |
| | | | | | * cpu.c, rtems/score/cpu.h: Use Context_Control_fp* instead of void* for fp_contexts. | ||||
* | Use Context_Control_fp* instead of void* for fp_contexts. | Ralf Corsepius | 2007-04-17 | 2 | -6/+6 |
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -3/+3 |
* | 2006-11-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-17 | 2 | -4/+4 |
| | | | | * rtems/score/types.h: Remove unsigned64, signed64. | ||||
* | Fix formatting. | Joel Sherrill | 2006-06-21 | 1 | -1/+1 |
* | PR1091/patch | Till Straumann | 2006-06-19 | 2 | -1/+7 |
| | | | | | * cpu_asm.S: Reduce mask from 0xffc to 0x3fc so only the vector bits are used when calculating the exception vector. | ||||
* | Formatting | Joel Sherrill | 2006-03-01 | 1 | -9/+9 |
* | Just "cc" in the clobbered register list for interrupt enable/disable/flash | Eric Norum | 2006-02-28 | 2 | -5/+24 |
| | | | | | operations. The "memory" barrier will move the the generic interrupt enable/disable/flash macros. | ||||
* | 2006-01-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-16 | 2 | -2/+8 |
| | | | | | | * rtems/score/cpu.h: Part of a large patch to improve Doxygen output. As a side-effect, grammar and spelling errors were corrected, spacing errors were address, and some variable names were improved. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-13 | 1 | -0/+2 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-08 | 2 | -2/+6 |
| | | | | * rtems/score/types.h: Eliminate unsigned16, unsigned32. | ||||
* | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 2 | -7/+6 |
| | | | | | * rtems/asm.h: Remove private version of CONCAT macros. Include <rtems/concat.h> instead. | ||||
* | 2005-06-07 Brett Swimley <brett.swimley@aedbozeman.com> | Joel Sherrill | 2005-06-07 | 3 | -6/+11 |
| | | | | | PR 803/patch * rtems/score/cpu.h, rtems/score/m68k.h: Correct definition of _VBR. | ||||
* | 2005-05-20 Chris Johns <chrisj@rtems.org> | Joel Sherrill | 2005-05-20 | 3 | -2/+6 |
| | | | | * rtems/score/cpu.h, rtems/score/m68k.h: Change declaration of _VBR. | ||||
* | 2005-05-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-04 | 2 | -1/+5 |
| | | | | * rtems/score/m68k.h: Change _ColdFire_VBR to _VBR. | ||||
* | 2005-05-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-03 | 3 | -3/+8 |
| | | | | | * rtems/score/cpu.h: Change definition of _VBR to a simple pointer. * rtems/score/m68k.h: Remove use of _Coldfire_VBR. | ||||
* | 2005-05-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-03 | 2 | -1/+5 |
| | | | | * cpu.c: Remove warning. | ||||
* | Auto-generated update. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | Cosmetics. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-08 | 3 | -52/+69 |
| | | | | | * Makefile.am: Split out preinstallation rules. * preinstall.am: New (Split out from Makefile.am). | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 6 | -12/+17 |
| | | | | | * rtems/m68k/m68302.h, rtems/m68k/m68360.h, rtems/m68k/qsm.h, rtems/m68k/sim.h, rtems/score/m68k.h: Header guards cleanup. | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 3 | -148/+9 |
| | | | | | | | PR 754/rtems * rtems/asm.h: New (relocated from .). * asm.h: Remove (moved to rtems/asm.h). * Makefile.am: Reflect changes above. | ||||
* | 2005-01-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-01 | 2 | -5/+14 |
| | | | | | | | | PR rtems/752 * rtems/m68k/m68302.h, rtems/m68k/m68360.h, rtems/m68k/qsm.h, rtems/m68k/sim.h: New (relocated from .). * m68302.h, m68360.h, qsm.h, sim.h: Remove. * Makefile.am: Reflect changes above. | ||||
* | Remove. | Ralf Corsepius | 2005-02-01 | 4 | -2086/+0 |
* | ColdFire ISA A+ instructions. | Eric Norum | 2005-01-28 | 3 | -8/+38 |
* | New header guard. | Ralf Corsepius | 2005-01-28 | 5 | -10/+10 |
* | 2004-01-28 Ralf Corsepius <ralf.corsepiu@rtems.org> | Ralf Corsepius | 2005-01-28 | 1 | -0/+5 |
| | | | | | * asm.h, rtems/score/cpu.h, rtems/score/m68k.h, rtems/score/types.h: New header guards. | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -6/+5 |
| | | | | | * rtems/score/types.h: Remove signed8, signed16, signed32, unsigned8, unsigned16, unsigned32. | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -5/+9 |
| | | | | * rtems/score/m68k.h: *_swap_u32( uint32_t ). | ||||
| | | | | * rtems/score/m68k.h: *_swap_u16( uint16_t ). | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -0/+6 |
| | | | | * rtems/score/types.h: #include <rtems/stdint.h>. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@freenet.de> | Ralf Corsepius | 2005-01-07 | 2 | -1/+5 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-01 | 2 | -10/+7 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | Cosmetics. | Ralf Corsepius | 2004-11-21 | 7 | -7/+0 |
* | 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-21 | 2 | -2/+7 |
| | | | | | * rtems/score/types.h: Use __rtems_score_types_h as preprocessor guard. | ||||
* | 2004-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-21 | 3 | -6/+14 |
| | | | | * asm.h: Add doxygen preamble. | ||||
* | 2004-11-19 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-19 | 2 | -2/+7 |
| | | | | | * rtems/score/m68k.h: Use (defined(__mc68020__) && !defined(__mcpu32__)) instead of defined(__mc68020__) to reflect GCC-3.4's expectations. | ||||
* | 2004-10-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-02 | 4 | -6/+21 |
| | | | | | | * rtems/score/cpu.h: Add doxygen preamble. * rtems/score/m68k.h: Add doxygen preamble. * rtems/score/types.h: Add doxygen preamble. | ||||
* | 2004-07-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-07-25 | 2 | -0/+6 |
| | | | | | * rtems/score/m68k.h: Add include of <stdint.h> for uint32_t used by endian swapping routines. |
