path: root/cpukit/score/cpu/m68k/sim.h (follow)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-7/+0
* Changed name of W, X, and Y macros for fields in the ClockJoel Sherrill1999-11-221-9/+9
| | | | Synthesizer Control Register to remove use of single letter names.
* Moved back up in tree.Joel Sherrill1999-02-191-0/+342
* Moved to proper rtems/scoreJoel Sherrill1999-02-191-342/+0
* changed so this file is usable from assembly files.Joel Sherrill1996-06-031-50/+64
| | | | no longer uses efi332.h
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+3
* Incorporated the submission from John S. GwynneJoel Sherrill1995-09-191-0/+325
<jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support.
