1999-11-22 | Changed name of W, X, and Y macros for fields in the Clock | Joel Sherrill | 1 | -9/+9 | |
Synthesizer Control Register to remove use of single letter names. | |||||
1999-02-19 | Moved back up in tree. | Joel Sherrill | 1 | -0/+0 | |
1999-02-19 | Moved to proper rtems/score | Joel Sherrill | 1 | -0/+0 | |
1996-06-03 | changed so this file is usable from assembly files. | Joel Sherrill | 1 | -50/+64 | |
no longer uses efi332.h | |||||
1995-10-06 | fixed missing CVS IDs | Joel Sherrill | 1 | -0/+3 | |
1995-09-19 | Incorporated the submission from John S. Gwynne | Joel Sherrill | 1 | -0/+325 | |
<jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support. |
