> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
outside RTEMS. Comment:
I found a couple of places other than RTEMS where I'd like to use
the declarations supplied in m68360.h. To make this easier to do,
I've redone the declarations in m68360.h to use standard C types.
specific register macros and correct code in rtems.s.
suggestion.
The definition of "BEGIN_DATA" should not be null; should be ".data".
Also, the definition of "BEGIN_BSS" should be ".bss". For this error,
the compiled object has codes that write on the text segment area.
It is fatal when the code runs on ROM.
no longer uses efi332.h
added CPU_M68K_EXTB_L model flag
<jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support
for interrupt handling and bfffo support, the two BSPs he submitted
(efi68k and efi332), and SGI Irix 5.3 host support.
like signal dispatching.
