line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
These were remnants of pre-Doxygen comment style.
* cpu.c, rtems/score/cpu.h, rtems/score/m68k.h:
* rtems/score/m68k.h: Don't include rtems/score/types.h,
rtems/stdint.h.
* rtems/score/m68k.h: Move set cacr, acr0, acr1 routines here to get
them out of a BSP.
* cpukit/sapi/include/confdefs.h: Add missing quote to string to
remove warning.
* cpukit/score/cpu/m68k/rtems/score/m68k.h: Add the default
priority level for large memory Coldfires.
* rtems/score/m68k.h: There is no point in defining the maximum
priorities to 255. priority.h will default it to this.
* cpu_asm.S: Add Coldfire FPU support.
* rtems/score/m68k.h: Change the Coldfire CPU defines to be based
on the instruction set. Add Tiny RTEMS support to the small memory
model RTEMS processors.
* rtems/score/cpu.h: Handle the new Tiny RTEMS support.
* rtems/score/m68k.h: Add stubs for mcf5307, mcf5407, mcfv4e.
operations. The "memory" barrier will move the the generic interrupt
enable/disable/flash macros.
PR 803/patch
* rtems/score/cpu.h, rtems/score/m68k.h: Correct definition of _VBR.
* rtems/score/cpu.h, rtems/score/m68k.h: Change declaration of _VBR.
* rtems/score/m68k.h: Change _ColdFire_VBR to _VBR.
* rtems/score/cpu.h: Change definition of _VBR to a simple pointer.
* rtems/score/m68k.h: Remove use of _Coldfire_VBR.
* rtems/m68k/m68302.h, rtems/m68k/m68360.h, rtems/m68k/qsm.h,
rtems/m68k/sim.h, rtems/score/m68k.h: Header guards cleanup.
* rtems/score/m68k.h: *_swap_u32( uint32_t ).
* rtems/score/m68k.h: *_swap_u16( uint16_t ).
* rtems/score/m68k.h: Use (defined(__mc68020__) && !defined(__mcpu32__))
instead of defined(__mc68020__) to reflect GCC-3.4's expectations.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/m68k.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* rtems/score/m68k.h: Add include of <stdint.h> for uint32_t used by
endian swapping routines.
* cpu.c, m68302.h, rtems/score/cpu.h, rtems/score/m68k.h: Convert to
using c99 fixed size types.
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h,
rtems/score/types.h: URL for license changed.
* rtems/score/m68k.h: Per PR227, mc68060 does not require FPSP
since it is now multilib'ed.
* include/rtems/score/ispsh7750.h, score/ispsh7750.c: Account for
name change.
* rtems/score/m68k.h: m68k_swap_u32 fix typo.
* rtems/score/m68k.h [M68K_COLDFIRE_ARCH] (CPU_swap_u16, CPU_swap_u32):
Generic implementation of endian swap primitives added for Coldfire
family.
significant things:
and PowerPC
same code base.
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
