* rtems/m68k/m68302.h, rtems/m68k/m68360.h: Sweep to make sure grep for
COPYRIGHT passes.
* rtems/m68k/m68302.h, rtems/m68k/m68360.h, rtems/m68k/qsm.h,
rtems/m68k/sim.h, rtems/score/m68k.h: Header guards cleanup.
* cpu.c, m68302.h, rtems/score/cpu.h, rtems/score/m68k.h: Convert to
using c99 fixed size types.
* qsm.h, sim.h: Remove efi68k and efi332 references as they are no
longer in the tree.
* m68360.h: Correct the order of fields in the ethernet structure
to account for the typo in MC68360UM (page 7-248).
* rtems/score/cpu.h: define CPU_Exception_frame for rdbg.
* m68302.h: Make buffer pointer in m302_SCC_bd volatile.
* sim.h: These changes enable RTEMS to automatically generate
the ram_init file used by gdb with the BDM patches. The 332 has
on-board chip select lines (for RAM and FLASH) that must be
configured before use of these peripherals. These patches parse
data from start.c where the chip select lines are configured in
the runtime executable and automatically generates the gdb
initialization file using the same settings. A great time saver.
A similar file, ram_init_FW (flash writable), is also generated
that the flash programming tool uses.
* BSP/start/start.c: Must be modified to support above.
* BSP/start/ram_init.ld, BSP/start/ram_init.sed: New files.
Synthesizer Control Register to remove use of single letter names.
outside RTEMS. Comment:
I found a couple of places other than RTEMS where I'd like to use
the declarations supplied in m68360.h. To make this easier to do,
I've redone the declarations in m68360.h to use standard C types.
no longer uses efi332.h
added CPU_M68K_EXTB_L model flag
<jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support
for interrupt handling and bfffo support, the two BSPs he submitted
(efi68k and efi332), and SGI Irix 5.3 host support.
