* | 2003-02-06 Ilya Alexeev <ilya@continuum.ru> | Joel Sherrill | 2003-02-06 | 1 | -2/+2 |
| | | | | | * m68360.h: Correct the order of fields in the ethernet structure to account for the typo in MC68360UM (page 7-248). | ||||
* | Moved back up in tree. | Joel Sherrill | 1999-02-19 | 1 | -0/+889 |
* | Moved to proper rtems/score | Joel Sherrill | 1999-02-19 | 1 | -889/+0 |
* | Patch from Eric Norum <eric@skatter.usask.ca> to make m68360.h usable | Joel Sherrill | 1999-01-20 | 1 | -357/+366 |
| | | | | | | | | outside RTEMS. Comment: I found a couple of places other than RTEMS where I'd like to use the declarations supplied in m68360.h. To make this easier to do, I've redone the declarations in m68360.h to use standard C types. | ||||
* | Updates from Eric Norum to use the mcpu32 flags and fix comments. | Joel Sherrill | 1996-05-01 | 1 | -27/+14 |
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 1 | -0/+893 |
added CPU_M68K_EXTB_L model flag |
