path: root/cpukit/score/cpu/m32c/include/rtems (follow)
* Add _CPU_Counter_frequency()Sebastian Huber2018-06-151-0/+2
| | | | | | | | | | Add rtems_counter_frequency() API function. Use it to initialize the counter value converter via the new system initialization step (RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation and the counter converter. It avoids an unnecessary pull in of the 64-bit integer division from libgcc. Update #3456.
* m32c/include/rtems/score/types.h: Eliminate this fileJoel Sherrill2018-03-122-50/+4
| | | | Updates #3327.
* Remove make preinstallChris Johns2018-01-257-0/+1354
