comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
PR 1599/cpukit
* cpu_asm.c: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1573/cpukit
* cpu_asm.c, rtems/score/cpu.h: Add a per cpu data structure which
contains the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* context_init.c, context_switch.S, cpu.c, cpu_asm.c, varvects.S: Add
include of config.h
* context_init.c, context_switch.S, cpu.c, cpu_asm.c: Correct file
headers.
* context_switch.S, cpu_asm.c, rtems/score/cpu.h: Add support for
restarting the currently executing thread. Fine tune alignment factor
as two-byte aligned and use this for critical structures.
* .cvsignore, ChangeLog, Makefile.am, context_init.c, context_switch.S,
cpu.c, cpu_asm.c, preinstall.am, varvects.S, varvects.h, rtems/asm.h,
rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/m32c.h,
rtems/score/types.h: New files.
