PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
* cpu.c, irq.c, rtems/score/lm32.h:
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1697/cpukit
* rtems/score/cpu.h: lm32 really needs aligned stack. Recent changes
highlighted that this macro was incorrect.
* rtems/score/lm32.h: Add lm32_read_interrupts().
PR 1599/cpukit
* irq.c: Rename _Context_Switch_necessary to _Thread_Dispatch_necessary
to more properly reflect the intent.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1573/cpukit
* irq.c, rtems/score/cpu.h: Add a per cpu data structure which contains
the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* irq.c: Change _exception_stack_frame into void*.
* rtems/score/cpu.h: Remove warning in _CPU_Context_Initialize.
* rtems/score/cpu.h: Make _gp global.
* cpu.c, cpu_asm.S, irq.c: Add include of config.h
* cpu.c: Provide body for CPU specific Idle thread. This halts on qemu
but is just a nop on a real cpu.
* cpu_asm.S, irq.c, rtems/score/cpu.h: Add lm32 gdb stub support.
* cpu.h: corrected the registers in Context_Control and
in CPU_Interrupt_frame to correspond to the saved frame in cpu_asm.S
Also switched on CPU_ISR_PASSES_FRAME_POINTER.
* cpu_asm.S: Moved the restore part of _CPU_Context_switch for
easier reading. Fixed _CPU_Context_restore, it now moves the
argument and branches to a label in _CPU_Context_switch. Removed
unnecessary saves of registers in context switch and irq handling.
Rewrote irq code to call the C helper. Added some documentation
* irq.c: New file derived from c4x and nios2.
* cpu_asm.S: We cannot use any other register than r0 without saving
them to the stack. (_ISR_Handler clears r0 right at the beginning)
* cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* .cvsignore: New file.
* ChangeLog, Makefile.am, cpu.c, cpu_asm.S, preinstall.am, rtems/asm.h,
rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/lm32.h,
rtems/score/types.h: New files.
