PR 1954/cpukit
* score/cpu/lm32/rtems/score/lm32.h: Protect against macro expansion.
* cpu.c, irq.c, rtems/score/lm32.h:
* rtems/score/lm32.h: Add lm32_read_interrupts().
* ChangeLog, Makefile.am, cpu.c, cpu_asm.S, preinstall.am, rtems/asm.h,
rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/lm32.h,
rtems/score/types.h: New files.
