* cpu_asm.S: Modify to properly dereference _ISR_Vector_table
now that it is dynamically allocated.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
<mark@ramix.com> of RAMIX.
fixed by Joel.
based on 3.6.0. It was very lucky that this went in as well as it
did.
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
