* | Added crude i960ka support. | Joel Sherrill | 2000-06-13 | 1 | -0/+2 |
* | Patch from Gerwin Pfab <pb@schenk.isar.de> to leave dispatching | Joel Sherrill | 1999-10-26 | 1 | -3/+4 |
| | | | | | disabled on exit to ISR Thread dispatching. This allows a context switch to finish under high high interrupt rates. | ||||
* | Patch from Jimen Ching <jimen@adtech-inc.com>: | Joel Sherrill | 1999-08-18 | 1 | -0/+45 |
| | | | | | | | | | | | | | | | Please take a look at this new patch. It contains a cleaner implementation of the reset operation. These patches are against 4.0.0. But the files did not change from the 3.6.0 release. Also, the cpu.h patch below still applies. I.e. instead of using i960ca_PRCB, use i960_PRCB. Explanation: The previous patch removed the use of the reset instruction, because it always fails. But this was due to the fact that some of the registers were corrupted by the re-init procedure. The new patches save and restore those registers when a re-init is done. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 1 | -0/+199 |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. |
