* score/cpu/i960/.cvsignore, score/cpu/i960/ChangeLog,
score/cpu/i960/Makefile.am, score/cpu/i960/asm.h,
score/cpu/i960/cpu.c, score/cpu/i960/cpu_asm.S,
score/cpu/i960/rtems/score/cpu.h, score/cpu/i960/rtems/score/i960.h,
score/cpu/i960/rtems/score/types.h: Removed.
like signal dispatching.
