Update #3943.
Update #3530.
Update #3533.
http://www.google-melange.com/gci/task/view/google/gci2012/7983217
* cpu.c, sse_test.c, rtems/score/cpu.h, rtems/score/i386.h,
rtems/score/interrupts.h:
* cpu.c, cpu_asm.S, sse_test.c: Add include of config.h
* cpu.c, cpu_asm.S, rtems/score/cpu.h, sse_test.c:
Added experimental SSE support.
