line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #2468.
Update #2468.
Since the FP area pointer is passed by reference in
_CPU_Context_Initialize_fp() the optional FP area adjustment via
_CPU_Context_Fp_start() is superfluous. It is also wrong with respect
to memory management, e.g. pointer passed to _Workspace_Free() may be
not the one returned by _Workspace_Allocate().
Close #1400.
Use de-facto standard BYTE_ORDER instead.
Close #2803.
On SMP configurations, it is a fatal error to call blocking operating
system with interrupts disabled, since this prevents delivery of
inter-processor interrupts. This could lead to executing threads which
are not allowed to execute resulting in undefined behaviour.
The ARM Cortex-M port has a similar problem, since the interrupt state
is not a part of the thread context.
Update #2811.
In contrast to _ISR_Get_level() the _ISR_Is_enabled() function evaluates
a level parameter and returns a boolean value.
Update #2811.
Update #2808.
Move CPU_PER_CPU_CONTROL_SIZE and the optional CPU_Per_CPU_control to
<rtems/score/cpuimpl.h> to hide it from <rtems.h>.
The thread dispatch inline option is no longer used.
Only use CPU_Per_CPU_control if it contains at least one filed. In GNU
C empty structures have a size of zero. In C++ structures have a
non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero,
then this structure is not used anymore.
Bug introduced by b04b76c6a0c87ffc9670d356e793108411ce355a.
Rename __log2table into _Bitfield_Leading_zeros since it acually returns
the count of leading zeros of an 8-bit integer. The value for zero is a
bit odd. Provide it unconditionally.
Define _CPU_SMP_Prepare_start_multitasking() as empty macro to prevent a
link-time error on SMP configurations.
Maximum number of processors of all systems supported by this CPU port.
Fixes #2515.
Update #2559.
Add CPU_CACHE_LINE_BYTES for the maximum cache line size in bytes. The
actual processor may use no cache or a smaller cache line size.
Update #2271.
Update #2268.
Without the source the error code does not say that much.
Let it be up to the CPU/BSP to determine the error code
reported on fatal shutdown.
This patch does not change the current behaviour, just
adds the option to handle the source of the fatal halt.
We must not alter the is executing indicator in
_CPU_Context_Initialize() since this would cause an invalid state during
a self restart.
The is executing indicator must be valid at creation time since
otherwise _Thread_Kill_zombies() uses an undefined value for not started
threads. This could result in a system life lock.
The current implementation of task migration in RTEMS has some
implications with respect to the interrupt latency. It is crucial to
preserve the system invariant that a task can execute on at most one
processor in the system at a time. This is accomplished with a boolean
indicator in the task context. The processor architecture specific
low-level task context switch code will mark that a task context is no
longer executing and waits that the heir context stopped execution
before it restores the heir context and resumes execution of the heir
task. So there is one point in time in which a processor is without a
task. This is essential to avoid cyclic dependencies in case multiple
tasks migrate at once. Otherwise some supervising entity is necessary to
prevent life-locks. Such a global supervisor would lead to scalability
problems so this approach is not used. Currently the thread dispatch is
performed with interrupts disabled. So in case the heir task is
currently executing on another processor then this prolongs the time of
disabled interrupts since one processor has to wait for another
processor to make progress.
It is difficult to avoid this issue with the interrupt latency since
interrupts normally store the context of the interrupted task on its
stack. In case a task is marked as not executing we must not use its
task stack to store such an interrupt context. We cannot use the heir
stack before it stopped execution on another processor. So if we enable
interrupts during this transition we have to provide an alternative task
independent stack for this time frame. This issue needs further
investigation.
Add and use _CPU_SMP_Start_processor(). Add and use
_CPU_SMP_Finalize_initialization(). This makes most
_CPU_SMP_Initialize() functions a bit simpler since we can calculate the
minimum value of the count of processors requested by the application
configuration and the count of physically or virtually available
processors in the high-level code.
The CPU port has now the ability to signal a processor start failure.
With the support for clustered/partitioned scheduling the presence of
particular processors can be configured to be optional or mandatory.
There will be a fatal error only in case mandatory processors are not
present.
The CPU port may use a timeout to monitor the start of a processor.
Remove RTEMS_COMPILER_PURE_ATTRIBUTE from _SMP_Get_current_processor()
and all _CPU_SMP_Get_current_processor(). Make inline ASM statements
volatile again. Test smptests/smpmigration01 showed that GCC optimizes
too much otherwise.
Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU
port must supply this function.
Delete _CPU_Context_switch_to_first_task_smp() and use
_CPU_Context_restore() instead.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Add CPU port specific per-CPU control.
Do not redefine CPU_USE_DEFERRED_FP_SWITCH.
Rename to _CPU_SMP_Processor_event_receive().
Rename to _CPU_SMP_Processor_event_broadcast().
Delete bsp_smp_interrupt_cpu().
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
Move the SMP lock implementation to the CPU port. An optimal SMP lock
implementation is highly architecture dependent. For example the memory
models may be fundamentally different.
The new SMP lock API has a flaw. It does not provide the ability to use
a local context for acquire and release pairs. Such a context is
necessary to implement for example the Mellor-Crummey and Scott (MCS)
locks. The SMP lock is currently used in _Thread_Disable_dispatch() and
_Thread_Enable_dispatch() and makes them to a giant lock acquire and
release. Since these functions do not pass state information via a
local context there is currently no use case for such a feature.
Delete bsp_smp_wait_for(). Other parts of the system work without
timeout, e.g. the spinlocks. Using a timeout here does not make the
system more robust.
Delete bsp_smp_cpu_state and replace it with Per_CPU_State. The
Per_CPU_State follows the Score naming conventions. Add
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state() functions to
change and observe states.
Use Per_CPU_State in Per_CPU_Control instead of the anonymous integer.
Add _CPU_Processor_event_broadcast() and _CPU_Processor_event_receive()
functions provided by the CPU port. Use these functions in
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state().
Add prototype for _SMP_Send_message().
Delete RTEMS_BSP_SMP_FIRST_TASK message. The first context switch is
now performed in rtems_smp_secondary_cpu_initialize(). Issuing the
first context switch in the context of the inter-processor interrupt is
not possible on systems with a modern interrupt controller. Such an
interrupt controler usually requires a handshake protocol with interrupt
acknowledge and end of interrupt signals. A direct context switch in an
interrupt handler circumvents the interrupt processing epilogue and may
leave the system in an inconsistent state.
Release lock in rtems_smp_process_interrupt() even if no message was
delivered. This prevents deadlock of the system.
Simplify and format _SMP_Send_message(),
_SMP_Request_other_cores_to_perform_first_context_switch(),
_SMP_Request_other_cores_to_dispatch() and
_SMP_Request_other_cores_to_shutdown().
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
