path: root/cpukit/score/cpu/i386/cpu.c (follow)
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-1/+1
| | | | * cpu.c: Include rtems/bspIo.h instead of bspIo.h.
* Removed warning.Joel Sherrill2000-01-141-0/+2
* Removed unitialized variable warning.Joel Sherrill2000-01-041-4/+3
* Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca>Joel Sherrill1999-07-291-1/+4
| | | | | to correct a typo CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES was actually typed in as CPU_CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* At the request of Gumby, the cpu is now halted rather than spinningJoel Sherrill1999-05-281-1/+1
| | | | on a fatal exception.
* Corrected name of constant so this would compile.Joel Sherrill1999-02-241-1/+1
* Patch from Emmanuel Raguet <raguet@crf.canon.fr>:Joel Sherrill1999-02-181-1/+9
| | | | | | | You will find enclosed a patch which contains, for Intel PC386 target : - an Ethernet driver for DEC21140 device based boards. - a simple cache management with paging mechanism.
* Patch from Eric Valette <valette@crf.canon.fr>:Joel Sherrill1998-08-311-6/+17
| | | | | | | | | | | | | | | | | | | Eric> NB : there is still a bug on PC386 serial line : exit does not Eric> flush the remaining output queue. As this is not a bug in the Eric> driver itself but somewhere in PC386 initialization/termios Eric> relationship it will be part of another patch. Eric> NB2 : As Emmanuel excerced the exception hanlder code, while Eric> porting the SMC driver to the new BSD stack, we found a bug Eric> in the exception handler : it shall not delete the current Eric> thread in case we are running at interrupt level. This will Eric> be part of another patch... So here is the patch. This patch fixes the two problems mentionned above + it use vpath mechanism intead of copying the irq related files in the right directory. This avoid to compile them each time and is more homogenous with other Makefiles.
* Patch from Eric Valette <valette@crf.canon.fr>:Joel Sherrill1998-08-211-0/+90
| | | | | | | | | | Here is a patch that enables to catch exception and get message before crashing RTEMS :) It should be generic to any Intel port although enabled only for pc386 BSP... [Joel] I fixed the bug I introduced in irq_asm.s...
* Spacing changesJoel Sherrill1998-08-211-1/+0
* Patch from Eric Valette <valette@crf.canon.fr>:Joel Sherrill1998-08-191-1/+8
| | | | | | | - Use the "hlt" instruction for the Idle thread, - Optimise interrupt PATH leadding to thread wakeup, - Preparation for Intel exception management that should come before the end of the week...
* Patch from Eric VALETTE <valette@crf.canon.fr>:Joel Sherrill1998-07-231-99/+0
| | | | | | | | | | | | | Here is a enhanced version of my previous patch. This patch enables to potentially share the new interrupt management code for all Intel targets (pc386, go32 and force386) bsp. Note : this patch is complete only for pc386. It still needs to be completed for go32 and force386. I carrefully checked that anything needed is in for force386 (only some function name changes for IDT manipulation and GDT segment manipulation). But anyway I will not be able to test any of theses targets...
* SPARC merged and successfully tested w/o interrupt supportJoel Sherrill1995-10-061-1/+0
* posix support initially addedJoel Sherrill1995-09-261-2/+2
* Removed unneeded referenced to rtems/fatal.hJoel Sherrill1995-09-221-1/+0
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-2/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-5/+16
* after testing go32 and cvme961Joel Sherrill1995-07-211-1/+8
* merged Linux UNIX simulator support (C)Joel Sherrill1995-07-181-2/+1
* Ada95, gnat, go32Joel Sherrill1995-07-121-17/+58
* Initial revisionJoel Sherrill1995-05-111-0/+121
