* cpu.c: Make _defaultExcHandler static.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* cpu.c, cpu_asm.S: Remove /*PAGE markers which were interpreted by a
long dead print script.
* Makefile.am: Reformat.
* cpu.c, sse_test.c, rtems/score/cpu.h, rtems/score/i386.h,
rtems/score/interrupts.h:
PR 1635/cpukit
* rtems/score/types.h: Refactoring of priority handling, to isolate the
bitmap implementation of priorities in the supercore so that priority
management is a little more modular. This change is in anticipation
of scheduler implementations that can select how they manage tracking
priority levels / finding the highest priority ready task. Note that
most of the changes here are simple renaming, to clarify the use of
the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
* cpu_asm.S: Formatting.
* rtems/score/registers.h: Remove structs with bit-fields. Add a mask
for cr3 page directory.
* cpu.c, cpu_asm.S, sse_test.c: Add include of config.h
PR 1469/cpukit
* cpu.c: Add dummy entry for (non-existing) exception #15.
Otherwise all slots for vectors >= 16 are one element off.
* rtems/score/cpu.h: Define _CPU_Interrupt_stack_setup() macro
which reserves space for the 'vector' arg to _C_dispatch_isr()
routine and aligns the irq stack to CPU_STACK_ALIGNMENT.
* rtems/score/cpu.h: Replaced misleading typedef of
CPU_Interrupt_frame by 'void'. The i386 port does not
pass any frame info to the interrupt handlers.
* ChangeLog, score/cpu/i386/ChangeLog: moved log messages
I had erroneously written to cpukit/Changelog to
cpukit/score/cpu/i386/ChangeLog.
* rtems/score/cpu.h: Add no return atrribute to _CPU_Context_restore()
since it is used for restarting self.
* cpu.c, rtems/score/cpu.h: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* rtems/score/cpu.h: Remove extraneous spaces.
* cpu.c: Stop using old-style defs.
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* cpu.c: Fix prototypes.
* rtems/score/cpu.h: Use memcpy() initialize FP structure and avoid
many casts and potential warnings.
* rtems/score/cpu.h, rtems/score/i386.h: Add missing prototypes.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* rtems/score/idtr.h: Sweep to make sure grep for COPYRIGHT passes.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* rtems/score/cpu.h: Eliminate the interrupt_table_segment and
interrupt_table_offset fields in the i386 CPU Table since they are
never read.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* cpu.c:
Use Context_Control_fp* instead of void* for fp_contexts.
* rtems/score/types.h: Remove unsigned64, signed64.
* rtems/score/cpu.h: Increase default stack size on i386 from 1K to 4K.
Most i386 targets are not memory strapped so making this a bit large
is not a burden. It lets more tests run. ticker and psxtimer will not
even run with 1K of stack.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
PR 754/rtems
* rtems/asm.h: New (relocated from .).
* asm.h: Remove (moved to rtems/asm.h).
* asm.h, rtems/score/cpu.h, rtems/score/i386.h, rtems/score/idtr.h,
rtems/score/interrupts.h, rtems/score/registers.h,
rtems/score/types.h: New header guards.
* rtems/score/types.h: Remove signed8, signed16, signed32,
unsigned8, unsigned16, unsigned32.
* rtems/score/i386.h: *_swap_u32( uint32_t ).
* rtems/score/i386.h: *_swap_u16( uint16_t ).
* rtems/score/types.h: #include <rtems/stdint.h>.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* rtems/score/types.h: Use __rtems_score_types_h as preprocessor
guard.
* asm.h: Add doxygen preamble.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/i386.h: Add doxygen preamble.
* rtems/score/idtr.h: Add doxygen preamble.
* rtems/score/interrupts.h: Add doxygen preamble.
* rtems/score/registers.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
