* | updated with new license information per Tony Bennett. | Joel Sherrill | 1997-04-22 | 1 | -10/+3 |
* | changed signed int to unsigned to eliminate warning | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | updates from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1996-08-15 | 1 | -2/+4 |
* | updartes from Tony Bennett | Joel Sherrill | 1996-04-22 | 1 | -256/+80 |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 1 | -45/+68 |
* | minor changes so it would compile | Joel Sherrill | 1995-12-05 | 1 | -3/+1 |
* | fixed null pointer dereference | Joel Sherrill | 1995-10-06 | 1 | -2/+2 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 1 | -1/+1 |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 1 | -3/+18 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -2/+2 |
* | Removed unneeded referenced to rtems/fatal.h | Joel Sherrill | 1995-09-22 | 1 | -1/+0 |
* | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 1995-09-19 | 1 | -3/+6 |
| | | | | | | single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | ||||
* | Initial attempt at building HP PA-RISC using Solaris hosted tools. | Joel Sherrill | 1995-09-12 | 1 | -3/+3 |
| | | | | Changed back to Newlib for Solaris UNIX simulator. | ||||
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 1 | -10/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | ||||
* | fix broken RCS Ids -- $ accidentally lost merging changes earlier | Joel Sherrill | 1995-08-22 | 1 | -1/+1 |
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 1 | -1/+21 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 1 | -1/+1 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+313 |
