* | 2002-06-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-27 | 1 | -1/+27 |
| | | | | | | * Makefile.am, cpu.c, cpu_asm.S, rtems.S: Modified to make this all compile again. It has been a while since we have had a semi-working hppa1.1-rtems cross compiler. :) | ||||
* | 2001-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-01-03 | 1 | -0/+1 |
| | | | | | | * rtems/score/cpu.h: Added _CPU_Initialize_vectors(). * cpu_asm.S: Modify to properly dereference _ISR_Vector_table now that it is dynamically allocated. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 1 | -0/+778 |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. |
