* | 2006-01-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-16 | 2 | -5/+10 |
| | | | | | | * rtems/score/cpu.h: Part of a large patch to improve Doxygen output. As a side-effect, grammar and spelling errors were corrected, spacing errors were address, and some variable names were improved. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-13 | 1 | -0/+2 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-08 | 2 | -2/+6 |
| | | | | * rtems/score/types.h: Eliminate unsigned16, unsigned32. | ||||
* | 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-27 | 2 | -4/+6 |
| | | | | | * rtems/asm.h: Remove private version of CONCAT macros. Include <rtems/concat.h> instead. | ||||
* | Auto-generated update. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | 2005-02-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-19 | 1 | -0/+4 |
| | | | | * rtems/score/cpu.h: Remove traces from NO_CPU. | ||||
* | Cosmetics. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | 2005-02-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-08 | 3 | -31/+48 |
| | | | | | * Makefile.am: Split out preinstallation rules. * preinstall.am: New (Split out from Makefile.am). | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 3 | -125/+9 |
| | | | | | | | PR 754/rtems * rtems/asm.h: New (relocated from .). * asm.h: Remove (moved to rtems/asm.h). * Makefile.am: Reflect changes above. | ||||
* | New header guard. | Ralf Corsepius | 2005-01-28 | 5 | -10/+10 |
* | 2004-01-28 Ralf Corsepius <ralf.corsepiu@rtems.org> | Ralf Corsepius | 2005-01-28 | 1 | -0/+5 |
| | | | | | * asm.h, rtems/score/cpu.h, rtems/score/h8300.h, rtems/score/types.h: New header guards. | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -6/+5 |
| | | | | | * rtems/score/types.h: Remove signed8, signed16, signed32, unsigned8, unsigned16, unsigned32. | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -16/+4 |
| | | | | * rtems/score/h8300.h: Remove RTEMS_CPU_HAS_16_BIT_ADDRESSES. | ||||
* | 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-24 | 2 | -0/+6 |
| | | | | * rtems/score/types.h: #include <rtems/stdint.h>. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@freenet.de> | Ralf Corsepius | 2005-01-07 | 2 | -1/+5 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-01 | 2 | -9/+7 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-12-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-12-10 | 2 | -1/+7 |
| | | | | | | PR 733/rtems * rtems/score/cpu.h: Remove output arg from inline asm in _CPU_ISR_Disable. | ||||
* | Cosmetics. | Ralf Corsepius | 2004-12-10 | 1 | -3/+3 |
* | Cosmetics. | Ralf Corsepius | 2004-11-21 | 4 | -4/+0 |
* | 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-21 | 2 | -2/+7 |
| | | | | | * rtems/score/types.h: Use __rtems_score_types_h as preprocessor guard. | ||||
* | 2004-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-21 | 3 | -6/+14 |
| | | | | * asm.h: Add doxygen preamble. | ||||
* | 2004-10-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-02 | 4 | -6/+21 |
| | | | | | | * rtems/score/cpu.h: Add doxygen preamble. * rtems/score/h8300.h: Add doxygen preamble. * rtems/score/types.h: Add doxygen preamble. | ||||
* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 2 | -4/+5 |
| | | | | * rtems/score/cpu.h: i960 obsoleted and all references removed. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 3 | -3/+0 |
* | Cleanup | Ralf Corsepius | 2004-04-06 | 1 | -12/+0 |
* | 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-06 | 3 | -31/+8 |
| | | | | | | * configure.ac: Remove (Merged into $(top_srcdir)/configure.ac). * Makefile.am: Don't include multilib.am. Reflect merging configure.ac into $(top_srcdir)/configure.ac. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -8/+13 |
| | | | | * Makefile.am: Install asm.h to $(includedir)/rtems. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 3 | -26/+30 |
| | | | | * cpu.c, rtems/score/cpu.h: Convert to using c99 fixed size types. | ||||
* | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 2 | -1/+5 |
| | | | | * configure.ac: RTEMS_TOP([../../../..]). | ||||
* | Unused. | Ralf Corsepius | 2004-03-08 | 2 | -4/+0 |
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -1/+5 |
| | | | | * configure.ac: Move RTEMS_TOP one subdir down. | ||||
* | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-19 | 2 | -2/+8 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+9 |
| | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. | ||||
* | 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-12 | 2 | -1/+5 |
| | | | | * configure.ac: Requires automake >= 1.8.1. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -1/+5 |
| | | | | * Makefile.am: Include compile.am, again. | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -14/+14 |
| | | | | * Makefile.am: Convert to using automake compilation rules. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -4/+6 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -10/+16 |
| | | | | * Makefile.am:Restore further parts having been lost. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -2/+52 |
| | | | | * Makefile.am: Restore file having been broken in last commit. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 2 | -59/+6 |
| | | | | * Makefile.am: Remove TMPINSTALL_FILES. | ||||
* | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-30 | 2 | -10/+20 |
| | | | | * Makefile.am: Add $(dirstamp) to preinstallation rules. | ||||
* | 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-23 | 2 | -18/+27 |
| | | | | * Makefile.am: Don't use gmake rules for preinstallation. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -2/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. |
