This was tracked as PR91.
* configure.in: Remove.
* cpu_asm.S: Modify to properly dereference _ISR_Vector_table
now that it is dynamically allocated.
* cpu_asm.S, rtems/score/cpu.h: Modified to better support
multilibing. These changes result in the code being able to
compile with the default gcc settings. It is not functional
in this configuration but does compile.
This update addresses the following:
+ the ISR enable/disable/flash macros now work with old gcc versions.
+ the UI CCR bits are now masked since other example code did so
+ _ISR_Dispatch disables interrupts during call setup
Together these removed the instabilities he was seeing.
_Interrupt_Manager_initialization.
to be consistent with other ports.
Hitachi H8 family. This port was done by Philip Quaife
<philip@qs.co.nz> of Q Solutions and sponsored by
Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1
to a Hitach H8300H. The port was updated to RTEMS 4.5 style
Makefiles/configure by Joel Sherrill <joel@OARcorp.com>.
While doing this Joel added support for the h8300-rtems to
binutils, gcc, newlib, and gdb.
NOTE: Philip submitted a BSP for a Hitachi evaluation board
which is being merged as a separate entity.
