updates #2452.
* rtems/score/h8300.h: Remove RTEMS_CPU_HAS_16_BIT_ADDRESSES.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/h8300.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* asm.h, cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/h8300.h,
rtems/score/types.h: URL for license changed.
Hitachi H8 family. This port was done by Philip Quaife
<philip@qs.co.nz> of Q Solutions and sponsored by
Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1
to a Hitach H8300H. The port was updated to RTEMS 4.5 style
Makefiles/configure by Joel Sherrill <joel@OARcorp.com>.
While doing this Joel added support for the h8300-rtems to
binutils, gcc, newlib, and gdb.
NOTE: Philip submitted a BSP for a Hitachi evaluation board
which is being merged as a separate entity.
