* cpu.c: Remove /*PAGE markers which were interpreted by a long dead
print script.
* cpu.c, rtems/asm.h, rtems/score/cpu.h:
* cpu.c, cpu_asm.S: Add include of config.h
* cpu.c: Change prototype of IDLE thread to consistently return void *
and take a uintptr_t argument.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* score/cpu/arm/cpu.c, score/cpu/avr/cpu.c, score/cpu/bfin/cpu.c,
score/cpu/c4x/cpu.c, score/cpu/h8300/cpu.c, score/cpu/i386/cpu.c,
score/cpu/m68k/cpu.c, score/cpu/mips/cpu.c, score/cpu/nios2/cpu.c,
score/cpu/no_cpu/cpu.c, score/cpu/sh/cpu.c, score/cpu/sparc/cpu.c,
cpukit/sapi/src/exinit.c: Move copying of CPU Table to shared
executive initialization.
* cpu.c, rtems/score/cpu.h: Convert to using c99 fixed size types.
* asm.h, cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/h8300.h,
rtems/score/types.h: URL for license changed.
Hitachi H8 family. This port was done by Philip Quaife
<philip@qs.co.nz> of Q Solutions and sponsored by
Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1
to a Hitach H8300H. The port was updated to RTEMS 4.5 style
Makefiles/configure by Joel Sherrill <joel@OARcorp.com>.
While doing this Joel added support for the h8300-rtems to
binutils, gcc, newlib, and gdb.
NOTE: Philip submitted a BSP for a Hitachi evaluation board
which is being merged as a separate entity.
