line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Since the FP area pointer is passed by reference in
_CPU_Context_Initialize_fp() the optional FP area adjustment via
_CPU_Context_Fp_start() is superfluous. It is also wrong with respect
to memory management, e.g. pointer passed to _Workspace_Free() may be
not the one returned by _Workspace_Allocate().
Close #1400.
Use de-facto standard BYTE_ORDER instead.
Close #2803.
On SMP configurations, it is a fatal error to call blocking operating
system with interrupts disabled, since this prevents delivery of
inter-processor interrupts. This could lead to executing threads which
are not allowed to execute resulting in undefined behaviour.
The ARM Cortex-M port has a similar problem, since the interrupt state
is not a part of the thread context.
Update #2811.
In contrast to _ISR_Get_level() the _ISR_Is_enabled() function evaluates
a level parameter and returns a boolean value.
Update #2811.
Update #2808.
Move CPU_PER_CPU_CONTROL_SIZE and the optional CPU_Per_CPU_control to
<rtems/score/cpuimpl.h> to hide it from <rtems.h>.
The thread dispatch inline option is no longer used.
Only use CPU_Per_CPU_control if it contains at least one filed. In GNU
C empty structures have a size of zero. In C++ structures have a
non-zero size. In case CPU_PER_CPU_CONTROL_SIZE is defined to zero,
then this structure is not used anymore.
The priority bit map can deal with a maximum of 256 priority values
ranging from 0 to 255. Consistently use an unsigned int for
computation, due to the usual integer promotion rules.
Make Priority_bit_map_Word definition architecture-independent and
define it to uint16_t. This was already the case for all architectures
except PowerPC. Adjust the PowerPC bitmap support accordingly.
Rename __log2table into _Bitfield_Leading_zeros since it acually returns
the count of leading zeros of an 8-bit integer. The value for zero is a
bit odd. Provide it unconditionally.
Maximum number of processors of all systems supported by this CPU port.
Update #2559.
Add CPU_CACHE_LINE_BYTES for the maximum cache line size in bytes. The
actual processor may use no cache or a smaller cache line size.
Update #2271.
Closes #2304
This patchs follows the latest commit by Daniel Hellstrom that
requires _CPU_Fatal_halt to have _source passed to it along with
_error number.
This work is based on the old or32 port (that has been
removed back in 2005) authored by Chris Ziomkowski. The patch includes the
basic functions every port should implement like: context switch, exception
handling, OpenRISC ABI and machine definitions and configurations.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Add CPU port specific per-CPU control.
Signed-off-by: Anthony Green <green@moxielogic.com>
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
integer literal that can be used by the assembler. This value will be
used to calculate offsets of structure members. These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language. The compiler
will provide defines to determine the current ABI. We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings. Also the offset values used by assembler
code are verfied.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* cpu.c, rtems/asm.h, rtems/score/cpu.h:
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/score/cpu.h: Assembler compatibility fixes.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1573/cpukit
* cpu_asm.S, rtems/asm.h, rtems/score/cpu.h: Add a per cpu data
structure which contains the information required by RTEMS for each
CPU core. This encapsulates information such as thread executing,
heir, idle and dispatch needed.
* rtems/score/cpu.h: Remove warning in _CPU_Context_Initialize.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
