* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* configure.ac, aclocal/canonical-target-name.m4: Readd NIOS2 and TI
C4x. Accidentally not done on 4.9 branch. :(
* score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog,
score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c,
score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c,
score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h,
score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h,
score/cpu/c4x/rtems/score/cpu_asm.h,
score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h,
score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog,
score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c,
score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c,
score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h,
score/cpu/nios2/rtems/score/cpu.h,
score/cpu/nios2/rtems/score/cpu_asm.h,
score/cpu/nios2/rtems/score/nios2.h,
score/cpu/nios2/rtems/score/types.h: New files.
* configure.ac, aclocal/canonical-target-name.m4,
score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch.
score/cpu/nios2/rtems/score/types.h: Removed.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Add CPU_SIMPLE_VECTORED_INTERRUPTS porting
parameter to indicate that the port uses the Simple Vectored
Interrupt model or the Programmable Interrupt Controller Model. The
PIC model is implemented primarily in the BSP and it is responsible
for all memory allocation.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* rtems/tic4x/c4xio.h: Sweep to make sure grep for COPYRIGHT passes.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
Eliminate evil casts.
* rtems/score/types.h: Use uint_least16_t for
Priority_Bit_map_control;
* rtems/score/types.h: Remove unsigned64, signed64.
* rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
* rtems/score/types.h: Eliminate unsigned16, unsigned32.
* rtems/asm.h: Remove private version of CONCAT macros.
Include <rtems/concat.h> instead.
* rtems/score/types.h: Remove signed8, signed16, signed32,
unsigned8, unsigned16, unsigned32.
* rtems/score/cpu.h: *_swap_u32( uint32_t ).
* rtems/score/types.h: #include <rtems/stdint.h>.
* rtems/score/types.h: Use __rtems_score_types_h as preprocessor
guard.
* asm.h: Add doxygen preamble.
* rtems/score/c4x.h: Add doxygen preamble.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/cpu_asm.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* rtems/score/cpu.h: i960 obsoleted and all references removed.
* c4xio.h, cpu.c, irq.c, rtems/score/cpu.h: Convert to using c99
fixed size types.
* rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all
references.
* cpu.c, cpu_asm.S, irq.c, rtems/score/c4x.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: URL for license changed.
* cpu.c, irq.c, rtems/score/cpu.h: Filled in something that was
marked XXX.
* rtems/score/c4xtypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* asm.h: Remove #include <rtems/score/targopts.h>.
Add #include <rtems/score/cpuopts.h>.
This was tracked as PR91.
* rtems/score/c4x.h: Modified to properly multilib. This required
using only macros predefined by gcc.
compiled and there is no comparable code for the C4x.
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
