line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
score/include/rtems/score/object.h: Removed extraneous commas.
* cpu.c, irq.c, rtems/score/cpu_asm.h: Sweep to make sure grep for
COPYRIGHT passes.
* .cvsignore, ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c,
preinstall.am, rtems/asm.h, rtems/score/bfin.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: New files.
