* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* rtems/score/cpu.h: Modifiy inline assembly language
constraints to use a data register as the CTL/STI
instructions requires. This is not only more correct,
it avoids GCC PR31787.
* rtems/score/cpu.h: Fix incorrect interrupt mask.
Eliminate evil casts.
* cpu.c, rtems/score/cpu.h: Use the default IDLE thread body.
* .cvsignore, ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c,
preinstall.am, rtems/asm.h, rtems/score/bfin.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: New files.
