path: root/cpukit/score/cpu/bfin/include/rtems/score (follow)
* bfin/include/rtems/score/types.h: Eliminate this fileJoel Sherrill2018-03-122-50/+4
| | | | Updates #3327.
* Remove make preinstallChris Johns2018-01-256-0/+1194
