closes #2443.
* rtems/score/avr.h: Add doxygen preamble.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/cpu_asm.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* cpu.c, cpu_asm.S, irq.c, rtems/score/c4x.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: URL for license changed.
like signal dispatching.
