path: root/cpukit/score/cpu/avr/avr/iom8hva.h (unfollow)
2016-01-19Remove AVR portJoel Sherrill1-84/+0
closes #2443.
2013-01-10cpukit: Use Consistent Beginning of Doxygen Group NotationJoel Sherrill1-1/+1
This is the result of a sed script which converts all uses of @{ into a consistent form.
2013-01-10score: Doxygen Clean Up Task #12Alex Ivanov1-0/+15
http://www.google-melange.com/gci/task/view/google/gci2012/8110207
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-1/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2010-05-102010-05-10 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill1-1/+1
* Makefile.am, cpu_asm.S, avr/boot.h, avr/common.h, avr/crc16.h, avr/delay.h, avr/eeprom.h, avr/fuse.h, avr/interrupt.h, avr/io.h, avr/io1200.h, avr/io2313.h, avr/io2323.h, avr/io2333.h, avr/io2343.h, avr/io43u32x.h, avr/io43u35x.h, avr/io4414.h, avr/io4433.h, avr/io4434.h, avr/io76c711.h, avr/io8515.h, avr/io8534.h, avr/io8535.h, avr/io86r401.h, avr/io90pwm1.h, avr/io90pwm216.h, avr/io90pwm2b.h, avr/io90pwm316.h, avr/io90pwm3b.h, avr/io90pwm81.h, avr/io90pwmx.h, avr/io90scr100.h, avr/ioa6289.h, avr/ioat94k.h, avr/iocan128.h, avr/iocan32.h, avr/iocan64.h, avr/iocanxx.h, avr/iom103.h, avr/iom128.h, avr/iom1280.h, avr/iom1281.h, avr/iom1284p.h, avr/iom128rfa1.h, avr/iom16.h, avr/iom161.h, avr/iom162.h, avr/iom163.h, avr/iom164.h, avr/iom165.h, avr/iom165p.h, avr/iom168.h, avr/iom168p.h, avr/iom169.h, avr/iom169p.h, avr/iom16hva.h, avr/iom16m1.h, avr/iom16u4.h, avr/iom2560.h, avr/iom2561.h, avr/iom32.h, avr/iom323.h, avr/iom324.h, avr/iom325.h, avr/iom3250.h, avr/iom328p.h, avr/iom329.h, avr/iom3290.h, avr/iom32c1.h, avr/iom32hvb.h, avr/iom32m1.h, avr/iom32u4.h, avr/iom32u6.h, avr/iom406.h, avr/iom48.h, avr/iom48p.h, avr/iom64.h, avr/iom640.h, avr/iom644.h, avr/iom645.h, avr/iom6450.h, avr/iom649.h, avr/iom6490.h, avr/iom64c1.h, avr/iom64m1.h, avr/iom8.h, avr/iom8515.h, avr/iom8535.h, avr/iom88.h, avr/iom88p.h, avr/iom8hva.h, avr/iomx8.h, avr/iomxx0_1.h, avr/iomxx4.h, avr/iomxxhva.h, avr/iotn11.h, avr/iotn12.h, avr/iotn13.h, avr/iotn13a.h, avr/iotn15.h, avr/iotn167.h, avr/iotn22.h, avr/iotn2313.h, avr/iotn24.h, avr/iotn25.h, avr/iotn26.h, avr/iotn261.h, avr/iotn28.h, avr/iotn43u.h, avr/iotn44.h, avr/iotn45.h, avr/iotn461.h, avr/iotn48.h, avr/iotn84.h, avr/iotn85.h, avr/iotn861.h, avr/iotn87.h, avr/iotn88.h, avr/iotnx4.h, avr/iotnx5.h, avr/iotnx61.h, avr/iousb1286.h, avr/iousb1287.h, avr/iousb162.h, avr/iousb646.h, avr/iousb647.h, avr/iousb82.h, avr/iousbxx2.h, avr/iousbxx6_7.h, avr/iox128a1.h, avr/iox128a3.h, avr/iox16a4.h, avr/iox16d4.h, avr/iox256a3.h, avr/iox256a3b.h, avr/iox32a4.h, avr/iox32d4.h, avr/iox64a1.h, avr/iox64a3.h, avr/lock.h, avr/parity.h, avr/pgmspace.h, avr/portpins.h, avr/power.h, avr/sfr_defs.h, avr/signal.h, avr/sleep.h, avr/version.h, avr/wdt.h, rtems/asm.h, rtems/score/cpu.h: Update to avr .h files from avr-libc 1.6.8. Tinker with code and includes to eliminate warnings. Now builds multilib. * avr/iom169pa.h, avr/iom16a.h, avr/iom16hva2.h, avr/iom16hvb.h, avr/iom16u2.h, avr/iom324pa.h, avr/iom32u2.h, avr/iom644p.h, avr/iom644pa.h, avr/iom649p.h, avr/iom64hve.h, avr/iom88pa.h, avr/iom8u2.h, avr/iotn2313a.h, avr/iotn24a.h, avr/iotn261a.h, avr/iotn4313.h, avr/iotn44a.h, avr/iotn461a.h, avr/iotn861a.h, avr/iox128d3.h, avr/iox192a3.h, avr/iox192d3.h, avr/iox256d3.h, avr/iox64d3.h, avr/signature.h: New files.
2009-11-30Whitespace removal.Ralf Corsepius1-1/+1
2009-08-062009-08-05 Josh Switnicki <josh.switnicki@utoronto.ca>Joel Sherrill1-0/+70
* Makefile.am: added AVR specific Header files to score/cpu/avr/avr. These are from avr-libc 1.6 and assumed to exist by AVR applications. * preinstall.am: Regenerated.
