Rename arm_status_irq_enable() to _ARMV4_Status_irq_enable() and
arm_status_restore() to _ARMV4_Status_restore().
Add and use _ARMV4_Exception_undef_default(),
_ARMV4_Exception_swi_default(), _ARMV4_Exception_data_abort_default(),
_ARMV4_Exception_pref_abort_default(),
_ARMV4_Exception_reserved_default(), _ARMV4_Exception_irq_default(), and
_ARMV4_Exception_fiq_default().
Provide proper CPU_Exception_frame definition for ARMv4 and use it.
Remove arm_cpu_context.
Rename arm_exc_abort_handler to ARMV4_Exception_abort_handler,
arm_exc_data_abort() to _ARMV4_Exception_data_abort(),
arm_exc_data_abort_set_handler() to
_ARMV4_Exception_data_abort_set_handler(),
arm_exc_prefetch_abort() to _ARMV4_Exception_prefetch_abort(), and
arm_exc_prefetch_abort_set_handler() to
_ARMV4_Exception_prefetch_abort_set_handler(),
Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt().
Move bsp_interrupt_dispatch() and arm_exc_interrupt() prototypes to new
file <rtems/score/armv4.h> since they have nothing to do with the CPU
port.
