* | score: Delete _Thread_BSP_context | Sebastian Huber | 2014-02-19 | 1 | -31/+5 |
| | | | | | | | | | | | | Do not return to BSP context in the exit() shutdown path. This makes it possible to re-use the initialization stack. It can be used for the interrupt stack for example. On targets with a small RAM this is a considerable benefit. This change eliminates also some special cases and simplifies the code. Delete _Thread_Set_global_exit_status(), _Thread_Get_global_exit_status() and _Thread_Stop_multitasking(). | ||||
* | arm: Include <rtems/score/cpu.h> | Sebastian Huber | 2013-01-07 | 1 | -3/+1 |
* | score misc: Clean up Doxygen #13 (GCI 2012) | Mathew Kallada | 2012-12-02 | 1 | -0/+6 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8013205 | ||||
* | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-24 | 1 | -0/+71 |
* rtems/score/armv7m.h, armv7m-context-initialize.c, armv7m-context-restore.c, armv7m-context-switch.c, armv7m-exception-handler-get.c, armv7m-exception-handler-set.c, armv7m-exception-priority-get.c, armv7m-exception-priority-set.c, armv7m-initialize.c, armv7m-isr-dispatch.c, armv7m-isr-enter-leave.c, armv7m-isr-level-get.c, armv7m-isr-level-set.c, armv7m-isr-vector-install.c, armv7m-multitasking-start-stop.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * rtems/score/arm.h: Define ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. * rtems/score/cpu.h, cpu_asm.S, cpu.c, arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S: Define CPU_HAS_HARDWARE_INTERRUPT_STACK to FALSE. Use ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. |
